Home » Archived » Memory Analyzer (MAT) » Minor CSVOutputter patch - 1 attachment
Minor CSVOutputter patch - 1 attachment [message #7185] Wed, 19 November 2008 15:19 Go to next message
Originally posted by: cgrinds.us.ibm.com
I noticed that Export to CSV uses the semicolon as the field separator. I
understand this is the standard in parts (all?) of Europe, but isn't the
standard in the US. This patch asks the Locale and tries to use the most
approriate format.
CSV is an ill defined spec.
Chris Grindstaff
cgrinds@us.ibm.com
Re: Minor CSVOutputter patch - 1 attachment [message #7573 is a reply to message #7185] Thu, 20 November 2008 07:29 Go to previous messageGo to next message
> approriate format.
Hi Chris, for one reason or another, I cannot read the attached patch...
But your suggestion makes absolutely sense. I know changed the code to
private static final char SEPARATOR = new
DecimalFormatSymbols().getDecimalSeparator() == ',' ? ';' : ':';
I read that countries using the comma as decimal point are the ones that
use the semicolon as separator char.
Is this in line with the patch you suggest?
Andreas.
Re: Minor CSVOutputter patch - 1 attachment [message #7594 is a reply to message #7573] Thu, 20 November 2008 07:30 Go to previous messageGo to next message
And, yes, it must read:
DecimalFormatSymbols().getDecimalSeparator() == ',' ? ';' : ',';
Re: Minor CSVOutputter patch - 1 attachment [message #7615 is a reply to message #7594] Thu, 20 November 2008 08:16 Go to previous message
andreas.buchen@sap.com (Andreas Buchen) wrote in
news:b806027f876b07d023ec6ba2db31aabf$1@www.eclipse.org:
Hello Andreas,
Yes that's exactly my patch.
Thanks for applying,
Chris
Chris Grindstaff
cgrinds@us.ibm.com
Previous Topic:Save Value to File
Next Topic:New inspectors
Current Time: Wed Nov 26 11:01:55 EST 2025
Powered by FUDForum. Page generated in 0.04978 seconds
