Home » Eclipse Projects » Remote Application Platform (RAP) » Restore minimized application or shell
Restore minimized application or shell [message #7179] Wed, 14 March 2007 09:25 Go to next message
how do I restore a minimized application or shell? The window just
disappears with no option to restore it.
Markus
Re: Restore minimized application or shell [message #7227 is a reply to message #7179] Wed, 14 March 2007 11:08 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hello Markus,
this is a limitation of the current implementation. The class
ShellListener does not yet have the shellIconified method which would
inform the server-side that a shell was minimized as well as there is no
way to represent a minimized shell on the client-side.
Until we fix this You could construct the shell with
new Shell( parent, RWT.CLOSE | RWT.RESIZE );
Rüdiger
Markus Krüger wrote:
> Hello,
> Best regards,
> Markus
Re: Restore minimized application or shell [message #7249 is a reply to message #7179] Wed, 14 March 2007 13:13 Go to previous messageGo to next message
when using the workbench you can run it maximized without a title bar by
implementing preWindowOpen of WorkbenchWindowAdvisor like this
public void preWindowOpen() {
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setShellStyle( RWT.NONE );
Rectangle bounds = Display.getCurrent().getBounds();
configurer.setInitialSize( new Point( bounds.width,
bounds.height ) );
configurer.setShowCoolBar( true );
configurer.setTitle( "Workbench Demo" );
There is still a small problem with the positioning of the menu.
Rüdiger
> Hello,
> Best regards,
> Markus
Re: Restore minimized application or shell [message #7306 is a reply to message #7249] Wed, 14 March 2007 13:45 Go to previous message
Originally posted by: roberto.sanchez.autonomind.com
If you add RWT.TITLE appears the Title (obviously ;-) ) but the menu is
positioned correctly and, of course, The Window can't be minimized.
configurer.setShellStyle( RWT.NONE | RWT.TITLE);
Bye.
Roberto.
> bounds.height ) );
> Cheers,
> Rüdiger
>> Hello,
>> Best regards,
>> Markus
Previous Topic:validation phase
Next Topic:TreeViewer sorts elements by name
Current Time: Fri Nov 07 08:27:49 EST 2025
Powered by FUDForum. Page generated in 0.26754 seconds
