| Serialize EMF Model using namespace prefix [message #80098] |
Tue, 17 April 2007 15:05  |
Originally posted by: dkrebs.tibco.com
I'm trying to run an xml document built with emf with some xslt and its
getting thrown off because the xml document child elements do not contain
the namespace prefix, does anyone know how I can tell the emf serializer
to write the prefix on all elements when going from memory to filesystem?
Also the first element has the right prefix but it starts with a captial
character and I'm trying to figure out where to configure it to use a
lowercase instead of uppercase is that on the genmodel or ecore model?
regards- Duncan
| Re: Serialize EMF Model using namespace prefix [message #80114 is a reply to message #80098] |
Tue, 17 April 2007 15:13  |
--------------090707030108000506020303
Duncan,
It's quite common for schemas to define local elements and attributes
that are not qualified and that's the default XMI serialization behavior
as well. You can use the annotations described in XML Schema to Ecore
Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>,
along with the XMLResource.OPTION_EXTENDED_META_DATA option so that the
annotations will be respected, to control how things are serialized
(element verses attribute, qualified verses unqualified) as well as the
actual XML names. You might want to write a small schema for the
serialization style you want and import it into Ecore to see how the
EAnnotations look and to generate the Java to see how the @model
annotations look.
Duncan Krebs wrote:
> Hi, I'm trying to run an xml document built with emf with some xslt
> and its getting thrown off because the xml document child elements do
> not contain the namespace prefix, does anyone know how I can tell the
> emf serializer to write the prefix on all elements when going from
> memory to filesystem? Also the first element has the right prefix but
> it starts with a captial character and I'm trying to figure out where
> to configure it to use a lowercase instead of uppercase is that on the
> genmodel or ecore model? regards- Duncan
<html>
<head>
http-equiv="Content-Type">
</head>
Duncan,<br>
<br>
behavior as well. You can use the annotations described in <a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a>, along with the
XMLResource.OPTION_EXTENDED_META_DATA option so that the annotations
will be respected, to control how things are serialized (element verses
attribute, qualified verses unqualified) as well as the actual XML
names.
| Re: Serialize EMF Model using namespace prefix [message #604807 is a reply to message #80098] |
Duncan,
Mapping
annotations look.
<html>
<head>
</head>
Duncan,<br>
<br>
names.
FUDForum. Page generated in 0.03120 seconds
