Home » Eclipse Projects » Eclipse Platform » Eclipse Refactor/rename Linux
Eclipse Refactor/rename Linux [message #79833] Sat, 21 June 2003 19:26 Go to next message
Originally posted by: unreallity.mail.ru
Hi there,
Can someone help me? I am working with the debian package of eclipse here.
My problem is, that Renaming (on refactor) is not working... i cant rename
functions, classes and so on.
Greetings
mc
Re: Eclipse Refactor/rename Linux [message #79906 is a reply to message #79833] Sun, 22 June 2003 04:31 Go to previous messageGo to next message
This is a know bug:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=197484
will be fixerd in the new build of eclipse (BTW, why isn't that
backported into 2.1.1?) or you can rebuild eclipse from source with
a JRE1.3:
apt-get source eclipse-sdk
cd eclipse-2.1
export JAVA_HOME=/usr/lib/j2se/1.3 # Blackdown debian packages
dpkg-buildpackage -uc -b -rfakeroot
dpkg -i ../*deb
Expect a new build (2.1-6) either late this evening or sometime
tomorrow from:
deb-src http://www.katzien.de/debian/eclipse ./
Jan, debian eclipse maintainer
Re: Eclipse Refactor/rename Linux [message #80048 is a reply to message #79906] Sun, 22 June 2003 07:39 Go to previous messageGo to next message
I tried to build it from source,
but therefore i needed jre1.3.. and jre 1.3 needs
libstdc++2.9-glibc2.1. and libstdc++2.9-glibc2.1 is an no-file, which i cant
find anywhere.
Greetings
Micha
>> here.
>> rename
> This is a know bug:
> a JRE1.3:
> cd eclipse-2.1
> dpkg -i ../*deb
> tomorrow from:
Re: Eclipse Refactor/rename Linux [message #80063 is a reply to message #80048] Sun, 22 June 2003 07:45 Go to previous messageGo to next message
Okay.. i have found the libstdc++, but builpackage
still dies with:
root@DarkStar-Debian:~/eclipse-2.1# dpkg-buildpackage -uc -b -rfakeroot
dpkg-buildpackage: source package is eclipse
dpkg-buildpackage: source version is 2.1-5
dpkg-buildpackage: source maintainer is Takashi Okamoto <tora@debian.org>
dpkg-buildpackage: host architecture is i386
fakeroot debian/rules clean
dh_testdir
dh_testroot
rm -rf pre-install build-java-stamp build-native-stamp \
build-stamp uncompress-stamp java_build.log log
/home/knoppix/eclipse-2.1/build-tree \
/home/knoppix/eclipse-2.1/source-tree debian/eclipse
debian/about.mappings
echo /usr/lib/j2se/1.3
/usr/lib/j2se/1.3
dh_clean
debian/rules build
dh_testdir
# Add here commands to uncompress the package.
mkdir -p /home/knoppix/eclipse-2.1/source-tree
(cd /home/knoppix/eclipse-2.1/source-tree;/usr/lib/j2se/1.3/bin/ jar xf
.../upstream/eclipse-sourceBuild-srcIncluded-2.1.zip)
grep: /usr/lib/j2se/1.3/jre/lib/jvm.cfg: No such file or directory
/usr/lib/j2se/1.3/bin/i386/native_threads/jar: error while loading shared
libraries: libjvm.so: cannot open shared object file: No such file or
directory
make: *** [uncompress-stamp] Fehler 127
Greetings
mc
> cant find anywhere.
> Greetings
> Micha
>>> here.
>>> rename
>> This is a know bug:
>> a JRE1.3:
>> cd eclipse-2.1
>> dpkg -i ../*deb
>> tomorrow from:
Re: Eclipse Refactor/rename Linux [message #80078 is a reply to message #79906] Sun, 22 June 2003 07:52 Go to previous messageGo to next message
Hm... i cant get it to build, because jre1.3 package is not working right.
So i hope to get a deb package from you...
Greetings
mc
> still dies with:
> dh_testdir
> dh_testroot
> /usr/lib/j2se/1.3
> dh_clean
> debian/rules build
> dh_testdir
> directory
> Greetings
> mc
>> cant find anywhere.
>> Greetings
>> Micha
>>>> here.
>>>> rename
>>> This is a know bug:
>>> a JRE1.3:
>>> cd eclipse-2.1
>>> dpkg -i ../*deb
>>> tomorrow from:
Re: Eclipse Refactor/rename Linux [message #80092 is a reply to message #80063] Sun, 22 June 2003 11:20 Go to previous messageGo to next message
You try next (with jdk 1.4) :
--begin-------------------------------------------
org.eclipse.jdt.ui\ui\org\eclipse\jdt\ui\actions\RenameActio n.java.orig
Thu
May 15 08:42:35 2003
+++ org.eclipse.jdt.ui\ui\org\eclipse\jdt\ui\actions\RenameActio n.java
Fri
May 16 12:16:17 2003
@@ -113,7 +113,7 @@
protected void run(IStructuredSelection selection) {
if (fRenameJavaElement.isEnabled())
- fRenameJavaElement.run(selection);
((SelectionDispatchAction)fRenameJavaElement).run((IStructur edSelection)selection);
if (fRenameResource != null && fRenameResource.isEnabled())
fRenameResource.run(selection);
Recompile eclipse
regards
Haris Peco
> still dies with:
> dh_testdir
> dh_testroot
> /usr/lib/j2se/1.3
> dh_clean
> debian/rules build
> dh_testdir
> directory
> Greetings
> mc
>> cant find anywhere.
>> Greetings
>> Micha
>>>> here.
>>>> rename
>>> This is a know bug:
>>> a JRE1.3:
>>> cd eclipse-2.1
>>> dpkg -i ../*deb
>>> tomorrow from:
Re: Eclipse Refactor/rename Linux [message #80139 is a reply to message #80092] Sun, 22 June 2003 10:45 Go to previous messageGo to next message
This worked!!!!,
Thank you very, very much
Greetinga
michael
> Thu
> Fri
> @@ -113,7 +113,7 @@
> Recompile eclipse
> regards
> Haris Peco
>> still dies with:
>> dh_testdir
>> dh_testroot
>> /usr/lib/j2se/1.3
>> dh_clean
>> debian/rules build
>> dh_testdir
>> directory
>> Greetings
>> mc
>>> cant find anywhere.
>>> Greetings
>>> Micha
>>>>> here.
>>>>> rename
>>>> This is a know bug:
>>>> a JRE1.3:
>>>> cd eclipse-2.1
>>>> dpkg -i ../*deb
>>>> tomorrow from:
Re: Eclipse Refactor/rename Linux [message #80199 is a reply to message #80139] Sun, 22 June 2003 14:31 Go to previous messageGo to next message
This si work from Stanislav Bernatsky
regards
Haris Peco
mc wrote:
> This worked!!!!,
> Greetinga
> michael
>> Thu
>> Fri
>> @@ -113,7 +113,7 @@
>> Recompile eclipse
>> regards
>> Haris Peco
>>> still dies with:
>>> <tora@debian.org> dpkg-buildpackage: host architecture is i386
>>> dh_testdir
>>> dh_testroot
>>> /usr/lib/j2se/1.3
>>> dh_clean
>>> debian/rules build
>>> dh_testdir
>>> shared libraries: libjvm.so: cannot open shared object file: No such
>>> file or directory
>>> Greetings
>>> mc
>>>> cant find anywhere.
>>>> Greetings
>>>> Micha
>>>>>> here.
>>>>>> rename
>>>>> This is a know bug:
>>>>> a JRE1.3:
>>>>> cd eclipse-2.1
>>>>> dpkg -i ../*deb
>>>>> tomorrow from:
Re: Eclipse Refactor/rename Linux [message #80215 is a reply to message #80092] Sun, 22 June 2003 11:58 Go to previous messageGo to next message
> + ((SelectionDispatchAction)...;
Thats exactly the patch that I used in the upcoming -6 builds...
>> still dies with:
>> directory
This is probably because you are on unstable and using a jdk, which
is compiled with the old gcc-2.95
Anyway, I'm happy that you found the solution...
Jan
Re: Eclipse Refactor/rename Linux [message #80328 is a reply to message #79833] Mon, 23 June 2003 02:57 Go to previous message
Hello.
mc wrote:
> Hi there,
I think this is bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37846
Stanislav Bernatsky.
Previous Topic:package explorer font
Next Topic:org.eclipse.jdt.debug.core [API help]
Current Time: Thu Jul 10 04:05:46 EDT 2025
Powered by FUDForum. Page generated in 0.12307 seconds
