Eclipse Refactor/rename Linux [message #79833] |
Sat, 21 June 2003 19:26  |
Originally posted by: unreallity.mail.ru
Hi there,
Can someone help me? I am working with the debian package of eclipse here.
My problem is, that Renaming (on refactor) is not working... i cant rename
functions, classes and so on.
Greetings
mc
Re: Eclipse Refactor/rename Linux [message #80092 is a reply to message #80063] |
Sun, 22 June 2003 11:20   |
You try next (with jdk 1.4) :
--begin-------------------------------------------
org.eclipse.jdt.ui\ui\org\eclipse\jdt\ui\actions\RenameActio n.java.orig
Thu
May 15 08:42:35 2003
+++ org.eclipse.jdt.ui\ui\org\eclipse\jdt\ui\actions\RenameActio n.java
Fri
May 16 12:16:17 2003
@@ -113,7 +113,7 @@
protected void run(IStructuredSelection selection) {
if (fRenameJavaElement.isEnabled())
- fRenameJavaElement.run(selection);
((SelectionDispatchAction)fRenameJavaElement).run((IStructur edSelection)selection);
if (fRenameResource != null && fRenameResource.isEnabled())
fRenameResource.run(selection);
Recompile eclipse
regards
Haris Peco
mc wrote:
> Okay.. i have found the libstdc++, but builpackage
> still dies with:
> root@DarkStar-Debian:~/eclipse-2.1# dpkg-buildpackage -uc -b -rfakeroot
> dpkg-buildpackage: source package is eclipse
> dpkg-buildpackage: source version is 2.1-5
> dpkg-buildpackage: source maintainer is Takashi Okamoto <tora@debian.org>
> dpkg-buildpackage: host architecture is i386
> fakeroot debian/rules clean
> dh_testdir
> dh_testroot
> rm -rf pre-install build-java-stamp build-native-stamp \
> build-stamp uncompress-stamp java_build.log log
> /home/knoppix/eclipse-2.1/build-tree \
> /home/knoppix/eclipse-2.1/source-tree debian/eclipse
> debian/about.mappings
> echo /usr/lib/j2se/1.3
> /usr/lib/j2se/1.3
> dh_clean
> debian/rules build
> dh_testdir
> # Add here commands to uncompress the package.
> mkdir -p /home/knoppix/eclipse-2.1/source-tree
> (cd /home/knoppix/eclipse-2.1/source-tree;/usr/lib/j2se/1.3/bin/ jar xf
> ../upstream/eclipse-sourceBuild-srcIncluded-2.1.zip)
> grep: /usr/lib/j2se/1.3/jre/lib/jvm.cfg: No such file or directory
> /usr/lib/j2se/1.3/bin/i386/native_threads/jar: error while loading shared
> libraries: libjvm.so: cannot open shared object file: No such file or
> directory
> make: *** [uncompress-stamp] Fehler 127
> Greetings
> mc
> mc wrote:
>> I tried to build it from source,
>> but therefore i needed jre1.3.. and jre 1.3 needs
>> libstdc++2.9-glibc2.1. and libstdc++2.9-glibc2.1 is an no-file, which i
>> cant find anywhere.
>> Greetings
>> Micha
>> Jan Schulz wrote:
>>>> here.
>>>> rename
>>> This is a know bug:
>>> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=197484
>>> will be fixerd in the new build of eclipse (BTW, why isn't that
>>> backported into 2.1.1?) or you can rebuild eclipse from source with
>>> a JRE1.3:
>>> apt-get source eclipse-sdk
>>> cd eclipse-2.1
>>> export JAVA_HOME=/usr/lib/j2se/1.3 # Blackdown debian packages
>>> dpkg -i ../*deb
>>> Expect a new build (2.1-6) either late this evening or sometime
>>> tomorrow from:
>>> deb-src http://www.katzien.de/debian/eclipse ./
>>> Jan, debian eclipse maintainer
Re: Eclipse Refactor/rename Linux [message #80139 is a reply to message #80092] |
Sun, 22 June 2003 10:45   |
This worked!!!!,
Thank you very, very much
Greetinga
michael
> Thu
> Fri
> @@ -113,7 +113,7 @@
> Recompile eclipse
> regards
> Haris Peco
>> still dies with:
>> dh_testdir
>> dh_testroot
>> /usr/lib/j2se/1.3
>> dh_clean
>> debian/rules build
>> dh_testdir
>> directory
>> Greetings
>> mc
>>> cant find anywhere.
>>> Greetings
>>> Micha
>>>>> here.
>>>>> rename
>>>> This is a know bug:
>>>> a JRE1.3:
>>>> cd eclipse-2.1
>>>> dpkg -i ../*deb
>>>> tomorrow from:
Re: Eclipse Refactor/rename Linux [message #80199 is a reply to message #80139] |
Sun, 22 June 2003 14:31   |
This si work from Stanislav Bernatsky
regards
Haris Peco
mc wrote:
> This worked!!!!,
> Greetinga
> michael
>> Thu
>> Fri
>> @@ -113,7 +113,7 @@
>> Recompile eclipse
>> regards
>> Haris Peco
>>> still dies with:
>>> <tora@debian.org> dpkg-buildpackage: host architecture is i386
>>> dh_testdir
>>> dh_testroot
>>> /usr/lib/j2se/1.3
>>> dh_clean
>>> debian/rules build
>>> dh_testdir
>>> shared libraries: libjvm.so: cannot open shared object file: No such
>>> file or directory
>>> Greetings
>>> mc
>>>> cant find anywhere.
>>>> Greetings
>>>> Micha
>>>>>> here.
>>>>>> rename
>>>>> This is a know bug:
>>>>> a JRE1.3:
>>>>> cd eclipse-2.1
>>>>> dpkg -i ../*deb
>>>>> tomorrow from:
FUDForum. Page generated in 0.26842 seconds
