Can not see complete Code (Java) [message #79765] |
Wed, 22 June 2005 13:05  |
Originally posted by: abhijat-vatsyayan.bms.com.donotspam.something
I could not locate this information using search. Mostly because I think
I am not using the correct search terms.
I have been using eclipse for sometime now and I recently noticed (in a
new install) that when I start navigating java code (using "Open
Declaration"), the editor starts showing part of the java code (only the
node that corresponds to selection. Hence if I select a method, the
editor will only show the method node (declaration and implementation if
any). I can not scroll up or down to other methods in the editor. I can
always close the file and open it but I have not been able to figure
out how to change this behaviour to always have the option of scrolling
up or down to other parts of the java file (after using the "Open
Declaration").
Abhijat
Re: Can not see complete Code (Java) [message #80045 is a reply to message #79765] |
Thu, 23 June 2005 11:33  |
Originally posted by: eclipse.rizzoweb.com
Abhijat Vatsyayan wrote:
> always close the file and open it but I have not been able to figure out
> how to change this behaviour to always have the option of scrolling up
> Declaration").
See this FAQ: http://eclipsewiki.editme.com/JavaEditor#showOnlySelectedIte m
HTH,
Eric
FUDForum. Page generated in 0.12746 seconds
