Home » Eclipse Projects » Eclipse Platform » i18n support for properties file
i18n support for properties file [message #79601] Fri, 20 June 2003 18:54 Go to next message
Hello, can eclipse editor automatically convert i18n character via
native2ascii?
Is there such a plugin?
-Dan
Re: i18n support for properties file [message #79848 is a reply to message #79601] Sat, 21 June 2003 20:54 Go to previous messageGo to next message
Am I asking the right group?
-Dan
"Dan Tran" <danttran@hotmail.com> wrote in message
news:bd03ap$h6h$1@rogue.oti.com...
> native2ascii?
> Thanks
> -Dan
Re: i18n support for properties file [message #82569 is a reply to message #79848] Wed, 25 June 2003 16:52 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
You're asking the right group, so this probably means that nobody knows
of such a plugin. There is no support for this in Eclipse itself.
Currently, you can set the encoding to use when reading a file, but
there is no support for conversion of encodings.
> -Dan
>>native2ascii?
>>Thanks
>>-Dan
Re: i18n support for properties file [message #82620 is a reply to message #82569] Wed, 25 June 2003 17:11 Go to previous message
I try that, but this setting applies to all file types.
This wont work. Also I am using struts which load i18n properties file
based on locale setting and it requireds the file to be ascii encoding
-Dan
"John Arthorne" <John_Arthorne@oti.com_> wrote in message
news:3EFA0B86.8000604@oti.com_...
> > -Dan
> >>native2ascii?
> >>Thanks
> >>-Dan
Previous Topic:remote jsp edit
Next Topic:How to access project properties like the source and output folders on build path
Current Time: Sun Jul 27 06:24:50 EDT 2025
Powered by FUDForum. Page generated in 0.03451 seconds
