Home » Archived » BIRT » charts problem
charts problem [message #79559] Thu, 06 October 2005 12:23 Go to next message
Originally posted by: ojauze.gmail.com
i am trying to display charts in HTML reports. It works in eclipse, with
the birt viewer but in my web app I can not display any charts. It works
when I choose PDF output format.
When I look at the generated html page, it seems that the img tag (which
should display an image from a temporary image file) does not have any
source.
Here is the img tag when it works (with eclipse or the web app viewer):
<img src="/birtViewer/run?__imageID=custom6" style=" width: 400pt; height:
250pt;">
Here is the img tag when it doesn't work (with my web app):
<img style=" width: 400pt; height: 250pt;">
It seems that a new http post is done when the report is displayed to get
the temporary image file. I can not figure out how can i do in my web app.
thanks for your help
Re: charts problem [message #79741 is a reply to message #79559] Fri, 07 October 2005 03:56 Go to previous messageGo to next message
Originally posted by: thmwg.web.de
Hi jauze,
I had the same problem. You have to add the imageDirectory and the
baseURL. Then it works.
Greetings
Thomas
jauze wrote:
> Hello,
> source.
> 250pt;">
Re: charts problem [message #79786 is a reply to message #79741] Fri, 07 October 2005 09:20 Go to previous messageGo to next message
Hi Thomas,
thanks for your answer.
Do you use the PlatformServletContext class in the EngineConfig ?
something like that:
config.setEngineHome( "" );
IPlatformContext context = new PlatformServletContext( servletContext, url
config.setEngineContext( context );
thanks
Re: charts problem [message #79998 is a reply to message #79786] Sun, 09 October 2005 07:21 Go to previous messageGo to next message
Hi jauze,
if you use the example given on the birt website you have to add following
lines.
HTMLRenderContext context= new HTMLRenderContext();
context.setImageDirectory("E:\\Entwicklung\\JBoss4\\server\\default\\deploy\\test.war ");
context.setBaseImageURL("http://localhost:8080/test");
Hope it helps.
Thomas
jauze wrote:
> Hi Thomas,
> thanks
Re: charts problem [message #80133 is a reply to message #79998] Mon, 10 October 2005 08:03 Go to previous message
hello Thomas,
thank you, it works
have a nice day
Previous Topic:BIRT vs Business Objects vs Crystal Reports
Next Topic:Tomcat oracle table processing runtime error
Current Time: Thu Nov 06 19:56:55 EST 2025
Powered by FUDForum. Page generated in 0.07397 seconds
