Home » Language IDEs » ServerTools (WTP) » Adding server to existing project?
Adding server to existing project? [message #79554] Wed, 02 March 2005 18:10 Go to next message
Is it possible to configure an existing project to use the Web Tools,
specifically to deploy to a Tomcat server? Currently when I go to the
project's Server properties, it says "This project cannot be deployed to a
server." If I just add the Tomcat libraries to the classpath, would that
work? (And how do I add those libraries?)
Thanks. The Web Tools project looks great so far.
Jacob
Re: Adding server to existing project? [message #79762 is a reply to message #79554] Thu, 03 March 2005 09:29 Go to previous messageGo to next message
Jacob Weber wrote:
> Hello,
> Jacob
Jacob,
You need to set a tomcat server runtime on the project to get the
project compile against tomcat. To set a server runtime you need to
create one using Windows -> Preferences -> Server -> Installed Runtimes
and click Add to setup the Apache tomcat server version you are
interested in. Once this is setup, when you bring up the Project ->
Properties -> Server you will have the tomcat server available in the
drop down list to set it on the project.
- Vijay
Re: Adding server to existing project? [message #79854 is a reply to message #79762] Thu, 03 March 2005 10:45 Go to previous message
Vijay,
Actually, I did that...I have a Tomcat 5.0 server set up in Preferences. But
it won't give me any choices in the Server properties for an existing
project. I can set up a new J2EE project from scratch, and it will give me
the option of using Tomcat with it. But my existing projects just say "This
project cannot be deployed to a server."
Jacob
"Vijay Bhadriraju" <vbhadrir@us.ibm.com> wrote in message
news:d07710$379$1@www.eclipse.org...
> You need to set a tomcat server runtime on the project to get the project
> compile against tomcat. To set a server runtime you need to create one
> using Windows -> Preferences -> Server -> Installed Runtimes and click Add
> to setup the Apache tomcat server version you are interested in. Once this
> is setup, when you bring up the Project -> Properties -> Server you will
> have the tomcat server available in the drop down list to set it on the
> project.
Previous Topic:Context menu for default JSP editor
Next Topic:WTP M3: Error opening xml document with XML Editor
Current Time: Sat Nov 15 16:59:20 EST 2025
Powered by FUDForum. Page generated in 0.03958 seconds
