Home » Newcomers » Newcomers » Check out from CVS failed with a folder named "resources"
Check out from CVS failed with a folder named "resources" [message #79552] Wed, 22 June 2005 02:31
Originally posted by: tattoo.smth.gmail.com
I have a problem when I checked out a whole project files from my CVS
server. Each time it failed on folder "resources" and said this folder
had already existed. I can found only one file in my local resources
folder. The following is the error message:
My eclipse version is 3.0.2
!ENTRY org.eclipse.team.cvs.core 4 272 Jun 21, 2005 16:01:46.437
!MESSAGE Problem creating folder: /Project1/resources. A resource
already exists on disk D:\Dev\Project1\resources.
!STACK 1
org.eclipse.core.internal.resources.ResourceException: A resource
org.eclipse.core.internal.resources.Folder.assertCreateRequi rements(Unknown
Source)
at org.eclipse.core.internal.resources.Folder.create(Unknown Source)
org.eclipse.team.internal.ccvs.core.resources.EclipseFolder. mkdir(Unknown
Source)
org.eclipse.team.internal.ccvs.core.client.ResponseHandler.r ecreatePhatomFolders(Unknown
Source)
org.eclipse.team.internal.ccvs.core.client.ResponseHandler.g etExistingFolder(Unknown
Source)
org.eclipse.team.internal.ccvs.core.client.UpdatedHandler.ha ndle(Unknown
Source)
org.eclipse.team.internal.ccvs.core.client.Request.executeRe quest(Unknown
Source)
at org.eclipse.team.internal.ccvs.core.client.Command.doExecute (Unknown
Source)
org.eclipse.team.internal.ccvs.core.client.Checkout.doExecut e(Unknown
Source)
org.eclipse.team.internal.ccvs.core.client.CheckoutWithOverw rite.doExecute(Unknown
Source)
at org.eclipse.team.internal.ccvs.core.client.Command$1.run(Unk nown Source)
org.eclipse.team.internal.ccvs.core.resources.EclipseSynchro nizer.run(Unknown
Source)
org.eclipse.team.internal.ccvs.core.resources.EclipseResourc e$2.run(Unknown
Source)
at org.eclipse.core.internal.resources.Workspace.run(Unknown Source)
org.eclipse.team.internal.ccvs.core.resources.EclipseResourc e.run(Unknown
Source)
at org.eclipse.team.internal.ccvs.core.client.Command.execute(U nknown
Source)
org.eclipse.team.internal.ccvs.ui.operations.CheckoutProject Operation.performCheckout(Unknown
Source)
org.eclipse.team.internal.ccvs.ui.operations.CheckoutProject Operation$1.run(Unknown
Source)
Source)
org.eclipse.team.internal.ccvs.ui.operations.CheckoutProject Operation.checkout(Unknown
Source)
org.eclipse.team.internal.ccvs.ui.operations.CheckoutSingleP rojectOperation.checkout(Unknown
Source)
org.eclipse.team.internal.ccvs.ui.operations.CheckoutOperati on.checkout(Unknown
Source)
org.eclipse.team.internal.ccvs.ui.operations.CheckoutOperati on.execute(Unknown
Source)
org.eclipse.team.internal.ccvs.ui.operations.CVSOperation.ru n(Unknown
Source)
at org.eclipse.team.internal.ui.actions.JobRunnableContext.run( Unknown
Source)
org.eclipse.team.internal.ui.actions.JobRunnableContext$3.ru nInWorkspace(Unknown
Source)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (Unknown
Source)
at org.eclipse.core.internal.jobs.Worker.run(Unknown Source)
!SUBENTRY 1 org.eclipse.core.resources 4 272 Jun 21, 2005 16:01:46.453
!MESSAGE A resource already exists on disk D:\Dev\Project1\resources.
Previous Topic:How to create workspace in existing folder?
Next Topic:software updates through eclipse
Current Time: Tue Nov 18 12:20:22 EST 2025
Powered by FUDForum. Page generated in 0.27677 seconds
