Is there a problem with the Newsgroups? [message #79424] |
Wed, 02 March 2005 15:16  |
I am having problems accessing the newsgroups via Thunderbird. It was
working fine, but yesterday our local systems gorup did some upgrades to
my system. Now, it no longer works. Normally, I would blame them for the
problem. But in this case I'm not so sure, since I can access Microsoft
and Intellij newsgroup servers.
I've deleted the account in Thunderbird several times to no avail. I
always get 'A News(NNTP) error occurred: Aborted by user' error dialog,
when I tried to anything with the newsgroup.
I am posting this via the web interface. Are there any problems the
newsgroups? If not, has anyone see this issue before. If so, do you know a
solution.
Jeff Duska
Re: Is there a problem with the Newsgroups? [message #79525 is a reply to message #79424] |
Wed, 02 March 2005 16:15  |
> a solution.
> Jeff Duska
I'm not using Thunderbird but a close relitive, Mozilla (current nightly
update).
I use:
(NNTP) news.eclipse.org
port 119
I am not using SSL.
Make sure the SMTP is set correctly. This is probably your problem. Call
your ISP and verify their SMTP address has not changed. I had the same
problem when they secured up their SMTP server. They actually changed
their address.
This problem has to be on your ISP side.
Thanks in Advance...
IchBin
____________________________________________________________ ______________
'The meeting of two personalities is like the contact of two chemical
substances:
if there is any reaction, both are transformed.'
- Carl Gustav Jung, (1875-1961), psychiatrist and psychologist
FUDForum. Page generated in 0.03857 seconds
