Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP stops processing events
TPTP stops processing events [message #79325] Tue, 01 August 2006 07:41 Go to next message
Originally posted by: torsr.orange.dk
I am using TPTP 4.2 (Callisto) to profile a standard Java web application
running in Tomcat 5.5. All seems to be working fine, but TPTP just stops
processing events after some thousands of events/some seconds during
execution and won't start processing again until I detach and reattach to
the agent. I don't have any data collection limits set.
Any ideas?
Thanks in advance
Torsten
Re: TPTP stops processing events [message #79555 is a reply to message #79325] Wed, 02 August 2006 10:12 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 004E2882852571BE_=
Content-Type: text/plain; charset="US-ASCII"
Are you using the Integrated Agent Controller (i.e. Local Direct
Connection) or the Agent Controller? If you're using IAC, try switching
to the Agent Controller. See section 4.0 of this document:
http://www.eclipse.org/tptp/platform/documents/speed_profili ng/speedUpProfiling.html
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Are you using the Integrated Agent Controller
(i.e. Local Direct Connection) or the Agent Controller? &nbsp;If you're
using IAC, try switching to the Agent Controller. &nbsp;See section 4.0
of this document: http://www.eclipse.org/tptp/platform/documents/speed_profili ng/speedUpProfiling.html</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 004E2882852571BE_=--
Re: TPTP stops processing events [message #79796 is a reply to message #79555] Thu, 03 August 2006 03:25 Go to previous message
I am using the standalone Agent Controller.
At some point I selected the option "Collect boundary classes excluded by
the filter set" with the default depth of 1, and this seems to have solved
my problem. The data collection doesn't "stall" anymore and a lot of
relevant classes are included now, so the statistics are actually much
more useful.
Of course I am not sure that this option solved my problem, but before I
set it I tried so many times without success and now it works perfect.
Torsten
Previous Topic:Missing steps in test behavior
Next Topic:Agent Controller could not be started
Current Time: Wed Jul 16 02:52:48 EDT 2025
Powered by FUDForum. Page generated in 0.29455 seconds
