Several brandings [message #79253] |
Wed, 26 March 2008 07:32  |
I recognized a strange behavior. Is it intended, that several brandings
for an application causes a "java.lang.IllegalStateException: The context
has been disposed."-Exception?
I have a very simple application running, with several brandings (use case
is, that the application should be customizable for different customers,
which could be easily done with brandings), but only the first
servlet-mapping seems to work?
Access to all other mappings causes the Exception.
Martin
Re: Several brandings [message #79268 is a reply to message #79253] |
Wed, 26 March 2008 12:26   |
Originally posted by: fappel.innoopract.com
the branding mechanism should work as you intend to use it. So this is
strange - could you please add the stacktrace, maybe this brings some
light in the dark...
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Martin Dilger [mailto:mdilger@splitshade.de]
Bereitgestellt: Mittwoch, 26. März 2008 12:32
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Several brandings
Betreff: Several brandings
context has been disposed."-Exception?
case is, that the application should be customizable for different
customers, which could be easily done with brandings), but only the
first servlet-mapping seems to work?
Martin
FUDForum. Page generated in 0.09163 seconds
