Home » Archived » M2M (model-to-model transformation) » [ATL] creating aggregation relation between model elements
[ATL] creating aggregation relation between model elements [message #79216] Tue, 15 April 2008 09:07 Go to next message
Dear all,
I'm creating some transformation rules in ATL and I've the problem that
I'm not being able to create containment (aggregation) relations between
elements in the target model. This two of the rules I'm using:
rule init {
from
enumerations : enumerationDC!EnumerationDC
to
coopnpackage: COOPNMetaModel!COOPNPackage(
name <- 'COOPN_Enum_Package'
rule ADT {
from
dc : enumerationDC!DCEnum
to
coopnadt: COOPNMetaModel!"COOPNMetamodel::ADTModule::COOPNADT"(
name<- dc.name
COOPNMetaModel!COOPNPackage and COOPNMetamodel::ADTModule::COOPNADT are
related with each other by a 0..* aggregation (named "ownedModules")
with COOPNMetaModel!COOPNPackage as the EContaining Class.
Any hint on how can now associate the created coopnadt to the previously
created coopnpackage by the ownedModules aggregation?
Thanks very much in advance for your time and help.
Luis Pedro
Re: [ATL] creating aggregation relation between model elements [message #79258 is a reply to message #79216] Tue, 15 April 2008 11:02 Go to previous messageGo to next message
--------------030305090005000303060509
I put some indications inside your code :
Luis Pedro a
Re: [ATL] creating aggregation relation between model elements [message #79272 is a reply to message #79258] Tue, 15 April 2008 11:43 Go to previous message
Thanks. I was not aware of that source of information! I was able to
solve the problem.
Again, thanks.
Luis Pedro
William Piers wrote:
> Hello,
> Luis Pedro a écrit :
>> Dear all,
>> that I'm not being able to create containment (aggregation) relations
>> between elements in the target model. This two of the rules I'm using:
>> rule init {
>> from
>> to
> ownedModules <- -- put here an OCL expression retrieving --
> the list of enumerationDC!DCEnum, later transformed into coopnadt,
> -- that you want to link with coopnpackage.
> -- this may be a kind of : ownedModules <- enumerations.ownedDCEnum
>> rule ADT {
>> from
>> to
>> name<- dc.name
>> are related with each other by a 0..* aggregation (named
>> "ownedModules") with COOPNMetaModel!COOPNPackage as the EContaining
>> Class.
>> previously created coopnpackage by the ownedModules aggregation?
> In order top better understand ATL implicit traceability links (between
> source and target model elements) I advise you to read those kind of
> simple examples : http://www.eclipse.org/m2m/atl/basicExamples_Patterns/
> Best Regards,
> William
>> Best regards,
>> Luis Pedro
Previous Topic:ATL installation problem
Next Topic:[ATL] UML 2 BPEL
Current Time: Sat Jul 26 02:29:57 EDT 2025
Powered by FUDForum. Page generated in 0.10586 seconds
