Specifing a program in the Run/Debug [message #79212] |
Thu, 28 August 2003 04:56  |
Originally posted by: gilhn.netscape.net
I have installed Eclipse 2.1.1 with CDT 1.1 on my Win2K OS.
I have downloaded the Borland C++ compiler and extracted it to
"c:\program files\BCC55" (I don't think it installed anything else).
I've tried to copile the standard "Hello World" program from the tutorial,
but I'm getting a "program not specified" message.
When I write the path of my compiler "c:\program files\BCC55\bin" I'm
getting a "Program does not exist" message. When I click on "Search..." a
window appears with no selections.
I've read previous articles in the newsgroup. I did choose the correct
Windows parser, so this is no the problem.
Can someone help me?
Gil
Re: Specifing a program in the Run/Debug [message #79267 is a reply to message #79226] |
Thu, 28 August 2003 10:34  |
ali wrote:
> Gil wrote:
>> "c:program filesBCC55" (I don't think it installed anything else).
>> tutorial, but I'm getting a "program not specified" message.
>> When I write the path of my compiler "c:program filesBCC55bin" I'm
>> Gil
> make sure u specify the right path to your make.exe and g++.exe in the
> makefile.
Gil is using Borland tools, though it probably is using bcc32 as compiler
and not g++! I don't know which make-tool is provided with BC++, but this
one you have to set as the default build command in the Projects Settings.
@Gil:
The Makefile syntax depends on this make-program though the Makefile needs
to adapt to this too, even though you could use the standard make command.
If you use make you could adapt your makefile like:
# CC is the compiler for plain C (probably the same as C++)
CC = bcc32
# CXX is the compiler for C++
CXX = bcc32
# LD sets the linker i guess its called blink.exe
# (or whatever the borland linker is named)
LD = blink
# compile flags
CXXFLAGS = <bcc32 specific compile flags>
# link flags like libs to link against
LDFLAGS = <blink specific flags for linking>
# the app target gets linked like this
app.exe: $(APP_OBJECTS)
$(LD) -o $@ $^ $(LDFLAGS)
# compile a single object file from source
%.o: %.cpp
$(CXX) $(CXXFLAGS) -o $@ -c $<
Be warned, I don't know if this works, since I don't use Borland Tools.
It's just a guess, but it should work with some adoption.
FUDForum. Page generated in 0.03580 seconds
