Home » Archived » Visual Editor (VE) » VE-inspired XML plugin?
VE-inspired XML plugin? [message #79188] Sat, 05 February 2005 17:50 Go to next message
Originally posted by: mmt_nin.yahoo.com
I have been searching to try to find a way to either extend the Visual
Editor, or build a new plugin that does near the same. Can someone tell me
how to make a very similar plugin that you drag/drop widgets that
generates XML? Is there already such a plugin that I haven't found? Any
and all help is deeply appreciated.
-Thanks!
Re: VE-inspired XML plugin? [message #79271 is a reply to message #79188] Mon, 07 February 2005 07:36 Go to previous messageGo to next message
That would be a great thing in my next project something like this would
rock. If I don't exists it would be great to start an project to provide
something like this if even possible at all. Maybe someone could tell us?:-)
Tom
> me how to make a very similar plugin that you drag/drop widgets that
> -Thanks!
Re: VE-inspired XML plugin? [message #79300 is a reply to message #79188] Mon, 07 February 2005 12:52 Go to previous messageGo to next message
Hi Megan,
The VE can be used for this, the only problem is that we don't really
document how. At one time we had an example plugin where you could open
an XML file (actually the EMF model that the visual editor uses
internally). This model is then able to be manipulated visually the
same way the VE can be now, the only difference is that there is no
..java code being updated or listened to for changes.
Could you please open a bugzilla feature request for us to get this
example working again and I think it will be a good starting point for
you to look at.
Joe Winchester
Re: VE-inspired XML plugin? [message #79315 is a reply to message #79300] Mon, 07 February 2005 08:55 Go to previous messageGo to next message
Joe Winchester wrote:
> Hi Megan,
>> tell me how to make a very similar plugin that you drag/drop widgets
>> that generates XML? Is there already such a plugin that I haven't
>> found? Any and all help is deeply appreciated.
> you to look at.
> Best regards,
> Joe Winchester
Thanks Joe. I do so. Are there any documents I could read about the
design of VE or do only have the source code (can I get it from cvs?).
Do you suggest any documents I have to read before I can jump in and
start reading the sources.
Tom
Re: VE-inspired XML plugin? [message #79474 is a reply to message #79315] Tue, 08 February 2005 07:46 Go to previous messageGo to next message
Originally posted by: tomAtLinux.gmx.at
>> Hi Megan,
>>> Visual Editor, or build a new plugin that does near the same. Can
>>> someone tell me how to make a very similar plugin that you drag/drop
>>> widgets that generates XML? Is there already such a plugin that I
>>> haven't found? Any and all help is deeply appreciated.
>> open an XML file (actually the EMF model that the visual editor uses
>> you to look at.
Done was not sure what component is the right maybe you have to modify:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=84569
Re: VE-inspired XML plugin? [message #79576 is a reply to message #79188] Tue, 08 February 2005 22:13 Go to previous messageGo to next message
There's not a plugin for VE that lets you do this, but the language and
the engine parts have been designed.
See xswt.sourceforge.net for details. The Update Manager URL is:
http://xswt.sourceforge.net/updates
Right now, there is a plug-in that just allows you to preview an XSWT
layout as you type it (whenever you save).
If you install via Update Manager, you will get a File/New wizard for
creating XSWT files. And the preview pane is available through
Window|Show View|Other..., then expand the XSWT node in the tree.
I had a conversation today with Gili about integrating this engine into
VE and this looks like something that the VE team might be interested in
doing.
Would anyone here be interested in helping?
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
Re: VE-inspired XML plugin? [message #80107 is a reply to message #79576] Mon, 14 February 2005 17:07 Go to previous messageGo to next message
> doing.
As already said I would but I don't know the internals of the VE and
XSWT. As a first step I checked out the sources of XSWT. Is there any
spec, DTD which tells me what XML-Elements exists? Can I use my own in
XSWT e.g. my own NumberWidget which derives from Text?
> Dave Orme
Re: VE-inspired XML plugin? [message #80225 is a reply to message #80107] Wed, 16 February 2005 08:56 Go to previous messageGo to next message
>> Regards,
>> Dave Orme
XSWT does not have a DTD per se.. it is based on reflection. There is a
bit of schema based notation... see more on
http://xswt.sourceforge.net/cgi-bin/wiki?XSWTCoreEngineDocum entation
Re: VE-inspired XML plugin? [message #80308 is a reply to message #79315] Wed, 16 February 2005 13:16 Go to previous messageGo to next message
Originally posted by: michail_matjuchin.at.ibm.com
>> Hi Megan,
>> you to look at.
>> Best regards,
>> Joe Winchester
> Tom
it is easy:
public class SampleAction implements IWorkbenchWindowActionDelegate {
private IWorkbenchWindow window;
private ISelection fSelection = null;
* The constructor.
public SampleAction() {
public void selectionChanged(IAction action, ISelection selection) {
fSelection = selection;
* The action has been activated. The argument of the method represents
the
* 'real' action sitting in the workbench UI.
* @see IWorkbenchWindowActionDelegate#run
public void run(IAction action) {
if (fSelection instanceof IStructuredSelection
&& ((IStructuredSelection) fSelection).size() == 1) {
Object object = ((IStructuredSelection) fSelection)
.getFirstElement();
if(object instanceof EditPart) {
EditPart editPart=(EditPart)object;
IJavaObjectInstance component = (IJavaObjectInstance)
editPart.getModel();
JavaClass modelType = (JavaClass) component.eClass();
EditDomain ed = EditDomain.getEditDomain(editPart);
DiagramData dd=ed.getDiagramData();
ResourceSet resSet = new ResourceSetImpl();
URI fileURI = URI.createFileURI("c:/temp/aaa.xml");
Resource resource =
resSet.createResource(fileURI);
resource.getContents().add(dd);
try {
resource.save(Collections.EMPTY_MAP);
catch(Exception ex) {
ex.printStackTrace();
Re: VE-inspired XML plugin? [message #80340 is a reply to message #80308] Wed, 16 February 2005 18:14 Go to previous messageGo to next message
> Resource resource =
This will screw up the editor because you just moved the diagram data
from the resource inside the VE to your resource.
Rich Kulp
Re: VE-inspired XML plugin? [message #80384 is a reply to message #80340] Thu, 17 February 2005 07:59 Go to previous messageGo to next message
>> Resource resource =
Will it work ? we really need it...
EditPart editPart = (EditPart) object;
IJavaObjectInstance component = (IJavaObjectInstance) editPart
.getModel();
DiagramData dd = ed.getDiagramData();
Resource res = dd.eResource();
ByteArrayOutputStream os = new ByteArrayOutputStream();
try {
res.save(os, Collections.EMPTY_MAP);
String xx = os.toString();
System.out.println("xx=" + xx);
BufferedWriter out = new BufferedWriter(new FileWriter(
"c:/temp/aaa.xml"));
out.write(xx);
out.close();
} catch (Exception ex) {
Many Thanks.
Re: VE-inspired XML plugin? [message #80597 is a reply to message #80384] Fri, 18 February 2005 09:43 Go to previous messageGo to next message
> editPart
> .getModel();
> try {
> out.write(xx);
> out.close();
> Many Thanks.
Note in the VE1.1 stearm (CVS HEAD) VE caches the EMF model, and a
table of content (instance variable name to XPath entry)... see
VEModelCacheUtility for more details on how. This cache is stored as a
IResource meta data
..metadata\.plugins\org.eclipse.core.resources\.projects\<project >\org.eclipse.ve.java.core\.cache\emfmodel
You are on the right track.... you can use the following as well,
XML_TEXT_OPTIONS = new HashMap(3);
XML_TEXT_OPTIONS.put(XMLResource.OPTION_PROCESS_DANGLING_HRE F,
XMLResource.OPTION_PROCESS_DANGLING_HREF_RECORD);
XML_TEXT_OPTIONS.put(XMLResource.OPTION_SAVE_TYPE_INFORMATIO N,
Boolean.TRUE);
XML_TEXT_OPTIONS.put(XMLResource.OPTION_LINE_WIDTH,
new Integer(100));
File f = ...
FileOutputStream os = new FileOutputStream(f);
res.save(os, XML_TEXT_OPTIONS);
os.close();
Re: VE-inspired XML plugin? [message #80722 is a reply to message #80107] Fri, 18 February 2005 14:51 Go to previous message
XSWT is designed to use reflection to automatically support any SWT
control on the classpath, including those that haven't been invented yet.
Dave Orme
Re: VE-inspired XML plugin? [message #605030 is a reply to message #79188] Mon, 07 February 2005 07:36 Go to previous message
Tom
> -Thanks!
Re: VE-inspired XML plugin? [message #605036 is a reply to message #79188] Mon, 07 February 2005 12:52 Go to previous message
Hi Megan,
you to look at.
Joe Winchester
Re: VE-inspired XML plugin? [message #605040 is a reply to message #79300] Mon, 07 February 2005 08:55 Go to previous message
> Hi Megan,
> you to look at.
> Best regards,
> Joe Winchester
Tom
Re: VE-inspired XML plugin? [message #605080 is a reply to message #79315] Tue, 08 February 2005 07:46 Go to previous message
>> Hi Megan,
>> you to look at.
Re: VE-inspired XML plugin? [message #605116 is a reply to message #79188] Tue, 08 February 2005 22:13 Go to previous message
doing.
Dave Orme
Re: VE-inspired XML plugin? [message #605242 is a reply to message #79576] Mon, 14 February 2005 17:07 Go to previous message
> doing.
> Dave Orme
Re: VE-inspired XML plugin? [message #605272 is a reply to message #80107] Wed, 16 February 2005 08:56 Go to previous message
>> Regards,
>> Dave Orme
Re: VE-inspired XML plugin? [message #605295 is a reply to message #79315] Wed, 16 February 2005 13:16 Go to previous message
>> Hi Megan,
>> you to look at.
>> Best regards,
>> Joe Winchester
> Tom
it is easy:
* The constructor.
the
.getFirstElement();
Resource resource =
try {
Re: VE-inspired XML plugin? [message #605304 is a reply to message #80308] Wed, 16 February 2005 18:14 Go to previous message
> Resource resource =
Rich Kulp
Re: VE-inspired XML plugin? [message #605314 is a reply to message #80340] Thu, 17 February 2005 07:59 Go to previous message
>> Resource resource =
.getModel();
try {
out.write(xx);
out.close();
Many Thanks.
Re: VE-inspired XML plugin? [message #605369 is a reply to message #80384] Fri, 18 February 2005 09:43 Go to previous message
> editPart
> .getModel();
> try {
> out.write(xx);
> out.close();
> Many Thanks.
IResource meta data
Boolean.TRUE);
new Integer(100));
File f = ...
os.close();
Re: VE-inspired XML plugin? [message #605412 is a reply to message #80107] Fri, 18 February 2005 14:51 Go to previous message
Dave Orme
Previous Topic:java.lang.NoClassDefFoundError for VE
Next Topic:GIF on a button
Current Time: Wed Nov 19 12:38:34 EST 2025
Powered by FUDForum. Page generated in 0.09904 seconds
