What about sorting ? [message #7097] |
Tue, 25 July 2006 15:06  |
I've got a look at this Nebula control, it looks interesting.
Is there a way to sort like the Table SWT component ?
What do you think of comp4swt - http://www.wdev91.com/comp4swt/ and its
FormattedText component (Date, Number and Mask formatter) ? Do you think
possible to add this kind of control in SWT ?
Re: What about sorting ? [message #9294 is a reply to message #9275] |
Fri, 18 August 2006 15:43  |
Enter a bug and I'll see whats necessary to add support for this...
Guido Küpper wrote:
>> Yes, you would sort the Grid exactly like you would sort Table (i.e.
>> you need to create dispose and recreate the items).
> Chris,
> do I understand this the right way? You are working with that (imho)
> ugly create - dispose mechanism SWT does? Is there a special reason for
> it or is it just for SWT interface compatibility (as I understood so
> far, the nebula grid is drawn on a canvas - so it should be possible to
> put the GridItem positions in a container, reorder this container by the
> sort criteria and redraw them dynamically)?
> Don't get me wrong, I have an huge amount of respect for your work, it
> should just be a hint to think about (because for column reordering you
> do not have to dispose and create columns again).
> Greets
> Guido
>>> its FormattedText component (Date, Number and Mask formatter) ? Do
>>> you think possible to add this kind of control in SWT ?
>> They look interesting. I'm sure SWT has considered similar widgets.
>> Nebula could benefit from widgets like these.
>> -Chris
Re: What about sorting ? [message #563309 is a reply to message #7097] |
Tue, 25 July 2006 16:46  |
Yes, you would sort the Grid exactly like you would sort Table (i.e. you
-Chris
Re: What about sorting ? [message #563978 is a reply to message #7121] |
Thu, 17 August 2006 04:32  |
Chris,
Greets
Guido
> -Chris
Re: What about sorting ? [message #564018 is a reply to message #9275] |
> Chris,
> Greets
> Guido
>> -Chris
FUDForum. Page generated in 0.03874 seconds
