Home » Eclipse Projects » OSEE » ORMF will not be joining the OSEE project at this time
ORMF will not be joining the OSEE project at this time [message #7075] Wed, 14 May 2008 07:20 Go to next message
The ORMF team has taken the decision that pursuing a close
collaboration with the OSEE team and achieving a tight integration of
ORMF into the OSEE framework is not feasible at this time. There are
several reasons for this decision the most important being that the
ORMF team simply lacks the resources to achieve that goal now. It is
also felt that in the near term it is best for the team to achieve a
deliverable based on existing code base for Useme that is being donated
by Etish Limited. In doing so the ORMF team will be able to quickly
deliver a useable system to the community which will stimulate
feedback. A scoping exercise based on this feedback will enable the
ORMF team will select the feature set of and formulate the project plan
for the 1.0 release of ORMF.
I would like to make it clear that this decision is in no way a
criticism of the value or viability of the OSEE project. In fact I
personally hope that downstream the ORMF project will be in a position
to reconsider this decision.
I would personally like to thank Don, Ryan and the rest of the OSEE
team for their initial invitation to join them and for all of the
support they have provided over the past weeks.
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme
|) ::: (| The Open Requirements Management Tool
====w=w==== [https://useme.dev.java.net]
Re: ORMF will not be joining the OSEE project at this time [message #7124 is a reply to message #7075] Wed, 14 May 2008 08:23 Go to previous messageGo to next message
On 2008-05-14 12:20:46 +0100, Joel Rosi-Schwartz
> Joel
I would like to join Joel in thanking the OSEE team for their openness
towards ORMF, for their welcome and for their support in recent weeks.
I sure hope we will have another opportunity to join efforts.
B.
                                  Barbara Rosi-Schwartz
Blog: http://www.brs4etish.blogspot.com
 |) ::: (|       The Open Requirements Management Tool
Re: ORMF will not be joining the OSEE project at this time [message #7172 is a reply to message #7075] Fri, 16 May 2008 11:46 Go to previous messageGo to next message
Sorry to hear that scarce resources prevent collaboration. What are your
ideas towards collaboration with the UML and Papyrus project. Are they
also put on hold?
thanks
/anders
Joel Rosi-Schwartz wrote:
> The ORMF team has taken the decision that pursuing a close collaboration
> with the OSEE team and achieving a tight integration of ORMF into the
> OSEE framework is not feasible at this time. There are several reasons
> for this decision the most important being that the ORMF team simply
> lacks the resources to achieve that goal now. It is also felt that in
> the near term it is best for the team to achieve a deliverable based on
> existing code base for Useme that is being donated by Etish Limited. In
> doing so the ORMF team will be able to quickly deliver a useable system
> to the community which will stimulate feedback. A scoping exercise based
> on this feedback will enable the ORMF team will select the feature set
> of and formulate the project plan for the 1.0 release of ORMF.
> I would personally like to thank Don, Ryan and the rest of the OSEE team
> for their initial invitation to join them and for all of the support
> Joel
Re: ORMF will not be joining the OSEE project at this time [message #7219 is a reply to message #7172] Sat, 17 May 2008 13:00 Go to previous message
Hi Anders,
Not at all sure. Once we get into a scoping exercise we will be in a
better position to understand what we can and cannot take on.
Joel
On 2008-05-16 16:46:42 +0100, "Anders W.Tell" <opensource@toolsmiths.se> said:
> your ideas towards collaboration with the UML and Papyrus project. Are
> they also put on hold?
> thanks
> /anders
>> Joel
Joel Rosi-Schwartz
Re: ORMF will not be joining the OSEE project at this time [message #570114 is a reply to message #7075] Wed, 14 May 2008 08:23 Go to previous message
> Joel
B.
Re: ORMF will not be joining the OSEE project at this time [message #570142 is a reply to message #7075] Fri, 16 May 2008 11:46 Go to previous message
also put on hold?
thanks
/anders
> Joel
Re: ORMF will not be joining the OSEE project at this time [message #570183 is a reply to message #7172] Sat, 17 May 2008 13:00 Go to previous message
Hi Anders,
Joel
> thanks
> /anders
>> Joel
Joel Rosi-Schwartz
Previous Topic:Collaboration Inquiry and Civil Engineering
Next Topic:User getting started
Current Time: Sat Jul 05 06:22:38 EDT 2025
Powered by FUDForum. Page generated in 0.03821 seconds
