| C++ libraries [message #79008] | Tue, 26 August 2003 07:25  |  |
| Eclipse User  |  |  |  |  | Originally posted by: par.emanuelsson.ericsson.com
 Are there C++ libraries included in the CDT (or elsewhere in Eclipse)?
 I am thinking on support for multithreading and synchronization, string
 handling, pattern matching, date and time handling, collection data types
 etc.
| Re: C++ libraries [message #79053 is a reply to message #79008] | Tue, 26 August 2003 21:23  |  |
 > etc.
 No.
 CDT is only the IDE part of Eclipse. It doesn't provide any compiler
 toolchain nor C++ libraries, as these are part of the compilers and the
 operating system etc..
 Multithreading and synchronization are very dependent on the operating
 system. Though, there are some free C++ wrappers around i.e. QThreads
 and ZThreads which wrap around the pthreads-C-library (UNIX). String
 handling is part of the C++ library coming with your prefered compiler
 toolchain. Date and time handling is also dependent on the OS even
 though there are wrappers in toolkits like Qt.
 Collection and datatypes are part of the STL if you think of Vectors,
 Lists, Stacks, Maps etc., these usually come with the C++ library of
 your compiler.
 As you can see, the support you ask for is provided elsewhere and
 depended on your compiler and OS. You could also take 3rd-party
 libraries. The field is so big and open, CDT couldn't provide it for any
 given platform Eclipse runs on. And I did not even talk about the
 Embedded Development with CDT.
FUDForum. Page generated in 0.03325 seconds
