Home » Language IDEs » ServerTools (WTP) » Error saving file
Error saving file [message #78994] Wed, 02 March 2005 04:56 Go to next message
When using 1.0M3 I get the following error whenever trying
to save a file. Anyone know why ?
!ENTRY org.eclipse.ui 2 0 2005-03-02 10:52:54.253
!MESSAGE Save Failed
!STACK 0
java.lang.IllegalArgumentException: Attempted to beginRule: =
L/test/WebContent/test/IdTag/testAttributesWithForm.jsp, does not match =
outer scope rule: F/src/java/j2ee/webapps/editor/WEB-INF/config
at org.eclipse.core.internal.runtime.Assert.isLegal(Assert.java :58)
at =
org.eclipse.core.internal.jobs.ThreadJob.illegalPush(ThreadJ ob.java:106)=
at org.eclipse.core.internal.jobs.ThreadJob.push(ThreadJob.java :200)
at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJo bs.java:=
58)
at =
org.eclipse.core.internal.jobs.JobManager.beginRule(JobManag er.java:186)=
at =
org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java=
:96)
at =
org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace=
..java:1657)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:169=
7)
at =
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOpera=
tion.java:110)
at =
org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(Worksp=
aceOperationRunner.java:73)
at =
aceOperationRunner.java:63)
at =
org.eclipse.ui.editors.text.TextFileDocumentProvider.execute Operation(Te=
xtFileDocumentProvider.java:441)
at =
org.eclipse.ui.editors.text.TextFileDocumentProvider.saveDoc ument(TextFi=
leDocumentProvider.java:700)
at =
org.eclipse.ui.texteditor.AbstractTextEditor.performSave(Abs tractTextEdi=
tor.java:3617)
at =
org.eclipse.ui.texteditor.AbstractTextEditor.doSave(Abstract TextEditor.j=
ava:3406)
at =
org.eclipse.wst.sse.ui.StructuredTextEditor.doSave(Structure dTextEditor.=
java:1233)
at org.eclipse.ui.internal.SaveableHelper$1.run(SaveableHelper. java:88)=
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:109=
at =
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext=
..java:344)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at =
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:=
624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69=
at =
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:62=
1)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:202=
6)
at =
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(Savea=
bleHelper.java:115)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:=
93)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:12=
72)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:26=
59)
at =
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2672=
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:69)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:100 3)
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:182=
at =
org.eclipse.ui.internal.commands.LegacyHandlerWrapper.execut e(LegacyHand=
lerWrapper.java:107)
at org.eclipse.core.commands.Command.execute(Command.java:260)
at =
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchK=
eyboard.java:418)
at =
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.j=
ava:698)
at =
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(Workbench=
Keyboard.java:741)
at =
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings=
(WorkbenchKeyboard.java:510)
at =
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$2(Work benchKeyboar=
d.java:453)
at =
org.eclipse.ui.internal.keys.WorkbenchKeyboard$1.handleEvent (WorkbenchKe=
yboard.java:229)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:783 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:841)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:866)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:851)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:879)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:875)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1181)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3121)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3024 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3480 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 19)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2539)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
at =
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:2=
93)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)=
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:1=
02)
at =
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActiva=
tor.java:228)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:=
333)
at =
150)
at =
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.jav=
a:39)
at =
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessor=
Impl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Re: Error saving file [message #79732 is a reply to message #78994] Thu, 03 March 2005 08:07 Go to previous message
Originally posted by: oliver.klar.gmx.de
I had the same problem. I deleted all folders under WORKSPACE/.metadata/
restarted Eclipse, and after recontructing my workspace settings it
works now.
I think, deleting only the jst and wst folders would also work.
Ian schrieb:
> !STACK 0
> at
> at
> org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJo bs.java:58)
> at
> at
> org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:96)
> at
> org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1657)
> at
> org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1697)
> at
> org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:110)
> at
> org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:73)
> at
> org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:63)
> at
> org.eclipse.ui.editors.text.TextFileDocumentProvider.execute Operation(TextFileDocumentProvider.java:441)
> at
> org.eclipse.ui.editors.text.TextFileDocumentProvider.saveDoc ument(TextFileDocumentProvider.java:700)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.performSave(Abs tractTextEditor.java:3617)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.doSave(Abstract TextEditor.java:3406)
> at
> org.eclipse.wst.sse.ui.StructuredTextEditor.doSave(Structure dTextEditor.java:1233)
> at
> org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:109)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
> at
> org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
> at
> org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:621)
> at
> org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2026)
> at
> org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:115)
> at
> org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:93)
> at
> org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1272)
> at
> org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2659)
> at
> org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2672)
> at
> org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:182)
> at
> org.eclipse.ui.internal.commands.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:107)
> at
> org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:418)
> at
> org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:698)
> at
> org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:741)
> at
> org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:510)
> at
> org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$2(Work benchKeyboard.java:453)
> at
> org.eclipse.ui.internal.keys.WorkbenchKeyboard$1.handleEvent (WorkbenchKeyboard.java:229)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
> at
> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
Previous Topic:Servlets refuse to compile
Next Topic:Still can't start Tomcat
Current Time: Tue Jun 03 06:36:03 EDT 2025
Powered by FUDForum. Page generated in 0.04500 seconds
