Home » Archived » Test and Performance Tools Platform (TPTP) » cant start profiling -> error
cant start profiling -> error [message #7061] Wed, 23 February 2005 09:53 Go to next message
Originally posted by: eclipse.knowthem.de
Hyades 3.2
Eclipse 3.0.1
Test connection success.
If I want to start profiling this message comes up:
IWAT0007I Either the agent controller is not started, or the java path is
incorrect. See log for more details
and the log:
Launching process failed, platform specific error is 267.
Path=C:\Programme\Java\jre1.5.0_01\bin\java.exe Process command line =
"C:\Programme\Java\jre1.5.0_01\bin\java.exe"
-XrunpiAgent:server=controlled -Xmx256m editor.Editor" severity="55"
version="1.0.1">
The Java Path is correct.
The Agent controller is running.
Re: cant start profiling -> error [message #8040 is a reply to message #7061] Sat, 26 February 2005 15:26 Go to previous messageGo to next message
Hi Gerrit,
If you can confirm that the Agent Controller is running, the paths are
correct and the editor.Editor is on the classpath, this appears to be a JVM
1.5.x defect. Please open a defect with all the information presented in
this post.
Paul
"Gerrit Brehmer" <eclipse@knowthem.de> wrote in message
news:cvi5ck$i56$1@www.eclipse.org...
> Hyades 3.2
> Eclipse 3.0.1
> and the log:
> version="1.0.1">
Re: cant start profiling -> error [message #8102 is a reply to message #8040] Mon, 28 February 2005 09:20 Go to previous messageGo to next message
Hi Paul,
I tested a little bit (also with the new TPTP 4.0 nightly build): Other
applications working normally with hyades. The app with the problem is a
RMI client. So must I run anything on the server from hyades? but i want
only profiling the client application.
Thanks for your help.
Gerrit
Paul Slauenwhite wrote:
> Hi Gerrit,
> this post.
> Paul
>> Hyades 3.2
>> Eclipse 3.0.1
>> and the log:
>> Path=C:ProgrammeJavajre1.5.0_01binjava.exe Process command line =
>> "C:ProgrammeJavajre1.5.0_01binjava.exe"
>> version="1.0.1">
Re: cant start profiling -> error [message #10803 is a reply to message #8102] Mon, 21 March 2005 09:41 Go to previous messageGo to next message
Hi Gerrit,
If you are only profiling the client in the RMI application, you will
only need the Agent Controller installed and running on the client's
machine. Profiling data will be truncated when the client makes the remote
invocation.
Paul
news:cvv9bh$bsa$1@www.eclipse.org...
> Hi Paul,
> Gerrit
> > Hi Gerrit,
are
JVM
in
> > this post.
> > Paul
> >> Hyades 3.2
> >> Eclipse 3.0.1
is
> >> and the log:
> >> version="1.0.1">
Re: cant start profiling -> error [message #18782 is a reply to message #7061] Fri, 27 May 2005 04:21 Go to previous message
Originally posted by: roger.hrzsoft.cn
I got the same error of IWAT0007I ..... while following the step
"Tutorial: Analyzing profiling data" that comes with Eclipse Help.
Hyades 4.0.0
Eclipse 3.1M7
OS: Fedora Core 2
I'm sure RAServer is running, but I'm not sure if Java Path is correct.
How could I check the path?
My error log:
org.eclipse.hyades.internal.execution.local.control.NoSuchAp plicationException
at org.eclipse.hyades.internal.execution.local.control.ProcessI mpl.launch(ProcessImpl.java:154)
at org.eclipse.hyades.trace.ui.internal.util.PDCoreUtil.launchT race(PDCoreUtil.java:757)
at org.eclipse.hyades.trace.ui.internal.launcher.ProfileJavaApp licationDelegate.launch(ProfileJavaApplicationDelegate.java: 76)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:734)
at org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:932)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:67)
Any suggestions?
On Wed, 23 Feb 2005 14:53:08 +0000, Gerrit Brehmer wrote:
> Hyades 3.2
> Eclipse 3.0.1
> and the log:
> version="1.0.1">
Previous Topic:profiling was application inside wsad - performance
Next Topic:Re: Generic Log Adapter Example
Current Time: Sat Nov 01 23:48:34 EDT 2025
Powered by FUDForum. Page generated in 0.04384 seconds
