| Set src folder using IProject [message #78909] |
Wed, 23 July 2003 01:40  |
Originally posted by: marius.venter.symbiotics.co.za
I created a plugin that creates a java project. Does anybody know how I set
the src folder in the Java Build Path programatically?
Does anybody know what files needs to be created for eclipse to see a
projects as a EAR, EJB, or Web project?
Thanks in advance
Marius
| Re: Set src folder using IProject [message #79192 is a reply to message #79178] |
Wed, 23 July 2003 09:20   |
Just my problem, the ear is not a java project and I've noticed the base sdk
doesnt support this, is there any other sdk I can use?
Marius
Jerome Lanneluc wrote:
> If the ear project is a Java project (its icon has a litle J), then it
> will work.
> Note I'm not sure how you created you ear project: the base Eclipse SDK
> doesn't have support for this.
> Jerome
> "Marius Venter" <marius.venter@symbiotics.co.za> wrote in message
> news:bflu8l$qir$1@eclipse.org...
>> I am trying to create the different projects in an ear project. Will
>> IJavaProject work for this.
>> Marius
>> > Instead of modifying the .classpath file, you can use
>> > IJavaProject.setRawClasspath(IClasspathEntry[], ...)
>> > Jerome
>> > news:bflba6$555$1@eclipse.org...
>> >> OK, found the awnser to the first question, just create the folder
> using
>> >> IFolder and and set it in the .classpath file
>> >> Marius Venter wrote:
>> >> > Hi,
>> >> > how
> I
>> >> > set the src folder in the Java Build Path programatically?
>> >> > a projects as a EAR, EJB, or Web project?
>> >> > Thanks in advance
>> >> > Marius
| Re: Set src folder using IProject [message #79235 is a reply to message #79192] |
Wed, 23 July 2003 09:24   |
Sorry, I don't know. You might want to repost your question with an
appropriate subject.
Jerome
news:bfm220$utf$1@eclipse.org...
sdk
> Marius
> > will work.
> > Jerome
> >> Marius
> >> > Jerome
> > using
> >> >> > Hi,
> >> >> > how
> > I
see
> >> >> > Thanks in advance
> >> >> > Marius
| Re: Set src folder using IProject [message #79370 is a reply to message #78909] |
Wed, 23 July 2003 12:58  |
I'll reply to the second part. See MyEclipse Enterprise Workbench
(www.myeclipseide.com). Already does what you're looking for.
W
news:bfl754$mk$1@eclipse.org...
set
> Thanks in advance
> Marius
FUDForum. Page generated in 0.07901 seconds
