Home » Language IDEs » Java Development Tools (JDT) » Refactoring event
Refactoring event [message #78863] Tue, 22 July 2003 21:38 Go to next message
Is there a way to receive an event from the "rename" refactoring or to hook
an action after it ran?
Thank you
Estelle
Re: Refactoring event [message #79068 is a reply to message #78863] Wed, 23 July 2003 05:05 Go to previous messageGo to next message
Originally posted by: adam_kiezun.ch.ibm.remove.com
there's work being done to allow you to participate in refactoring
see the draft of the proposal here:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/jdt-ui-h ome/r3_0/proposals/refactoring.html?rev=HEAD&content-typ e=text/html
and expect official version of the document soon (it will be posted to the jdt-ui-dev mailing list).
a.
eclipse.org
Re: Refactoring event [message #80549 is a reply to message #79068] Sat, 26 July 2003 11:41 Go to previous message
Originally posted by: vkyr.nospam-ision.net
"Adam Kiezun" <adam_kiezun@ch.ibm.remove.com> schrieb im Newsbeitrag
news:bflj4h$eos$1@eclipse.org...
ls/refactoring.html?rev=HEAD&content-type=text/html
Fine that there is now progress towards an reusable Eclipse Refactoring API.
One question in turn I have related to this and Eclipse 3.0 M2 is, if the
actual proposal and the javafamily example are supposed to already work? -
During my tryouts with the Eclipse 3.0 M2 javafamily (the JSP example) the
whole Eclipse IDE hangs in such a way when performing a participant JSP
rename refactoring , that you always have to kill the Eclipse process. - So
is the javafamily rename participants JSP example supposed to actually work
the way the draft proposal suggerates?
-Valentino
Previous Topic:How do I can import a file into exist project in workspace programmatically
Next Topic:Access to workspace root
Current Time: Sun Jul 27 08:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.03868 seconds
