Home » Archived » Test and Performance Tools Platform (TPTP) » Editor extensions
Editor extensions [message #78833] Wed, 26 July 2006 03:25 Go to next message
Originally posted by: laksefisker.hotmail.com
Greetings!
I was just wondering how one can use org.eclipse.hyades.test.ui.forms.BaseFormEditor
(based on Eclipse forms) for an editor extension. Alternatively, how one
can make a forms-compliant editor that also implements org.eclipse.hyades.ui.editor.IEditorExtension.
I tried just subclassing BaseFormEditor, but ran into a classcast exception
when the framework tried to cast it into an IEditorExtension. Subclassing
BaseFormEditor and implementing IEditorExtension didn't work either, as the
getSelection() methods implemented by both were incompatible.
I'm guessing the BaseFormEditor class isn't in there just for fun. How do
I utilize it? I'm extending the org.eclipse.hyades.ui.editorExtensions extension
point - is there some other extension point that will happily accept a BaseFormEditor?
Henrik W Lund
Re: Editor extensions [message #83464 is a reply to message #78833] Wed, 13 September 2006 07:38 Go to previous messageGo to next message
Henrik,
Have you answered your question?
Paul
"Henrik W Lund" <laksefisker@hotmail.com> wrote in message
news:baa5ffa099e8c87eac9306d325@news.eclipse.org...
> Greetings!
> org.eclipse.hyades.test.ui.forms.BaseFormEditor (based on Eclipse forms)
> for an editor extension. Alternatively, how one can make a forms-compliant
> exception when the framework tried to cast it into an IEditorExtension.
> Subclassing BaseFormEditor and implementing IEditorExtension didn't work
> either, as the getSelection() methods implemented by both were
> incompatible.
> extension point - is there some other extension point that will happily
> Henrik W Lund
Re: Editor extensions [message #83874 is a reply to message #83464] Thu, 21 September 2006 04:07 Go to previous message
Hello Paul,
Yes, I have. I reimplemented it, using TestLogViewer as a template for forms-compliance,
and BaseFormEditor for form content. It now looks exactly like BaseFormEditor,
but uses no deprecated classes or methods (100% forms-compliant).
I really like working with TPTP - it's both well documented and well supported.
I'll be using this list quite actively, I'm sure.
Henrik W Lund
> Henrik,
> Paul
>> Greetings!
>> forms) for an editor extension. Alternatively, how one can make a
>> IEditorExtension. Subclassing BaseFormEditor and implementing
>> IEditorExtension didn't work either, as the getSelection() methods
>> How do I utilize it? I'm extending the
>> org.eclipse.hyades.ui.editorExtensions extension point - is there
>> Thanks,
>> Henrik W Lund
Previous Topic:JVM problem running test with ant script
Next Topic:TPTP 4.2.0 installation using update mgr. fails
Current Time: Mon Jul 21 20:58:59 EDT 2025
Powered by FUDForum. Page generated in 0.04400 seconds
