Home » Eclipse Projects » Remote Application Platform (RAP) » Servlet delegate not registered without javax.servlet plugins
Servlet delegate not registered without javax.servlet plugins [message #78789] |
Fri, 21 March 2008 04:38  |
Originally posted by: n.lavoillotte.educagri.fr
Le Thu, 20 Mar 2008 17:01:33 +0000, nicolas lavoillotte a écrit:
> Hi all
> I'm using RAP extention (1.1.0_M1) with eclipse Europa 3.3
> My project is a RAP application and run correctly under eclipse.
> If I try to deploy on Tomcat 5.5.25 server with the build script :
> webappBuilder.xml, found in the org.eclipse.rap.demo.feature project and
> when I run my browser : http://localhost:8080/FNPL_etat/rap?startup=fnpl
> Tomacat says :
> Etat HTTP 404 - BridgeServlet: /FNPL_etat/rap
> message BridgeServlet: /FNPL_etat/rap
> description La ressource demandée (BridgeServlet: /FNPL_etat/rap) n'est
> pas disponible.
> If I try the sp_ commands with my apllictation for example :
> http://localhost:8080/FNPL_etat/sp_test
> ServletBridge says :
> Servlet delegate not registered.
> About ServletBridge, I 'm using the following cvs repository references :
> 1.0,:pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse,org.eclipse.equinox.
> http.servletbridge,org.eclipse.equinox.http.servletbridge
> servletbridge,org.eclipse.equinox.servletbridge
> 1.0,:pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse,equinox-incubator/org.
> eclipse.equinox.servletbridge.feature,org.eclipse.equinox.se rvletbridge.feature
> best regards
> My project use the followings bundles witout javax.servlet
<feature
> id="FNPL_etat.feature"
> label="RAP Deployment Feature"
> version="1.1.0.200803201546"
> provider-name="eclipse.org">
> <description url="http://www.example.com/description">
> [Enter Feature Description here.]
> </description>
> <copyright url="http://www.example.com/copyright">
> [Enter Copyright Description here.]
> </copyright>
> <license url="http://www.example.com/license">
> [Enter License Description here.]
> </license>
> <plugin
> id="FNPL_etat"
> download-size="0"
> install-size="0"
> version="1.0.0"
> unpack="false"/>
> <plugin
> id="org.hibernate.fnpl"
> download-size="0"
> install-size="0"
> version="1.0.0"
> unpack="false"/>
> <plugin
> id="org.eclipse.core.commands"
> download-size="0"
> install-size="0"
> version="3.3.0.I20070605-0010"
> unpack="false"/>
> <plugin
> id="org.eclipse.core.contenttype"
> download-size="0"
> install-size="0"
> version="3.2.100.v20070319"
> unpack="false"/>
> <plugin
> id="org.eclipse.core.jobs"
> download-size="0"
> install-size="0"
> version="3.3.1.R33x_v20070709"
> unpack="false"/>
> <plugin
> id="org.eclipse.core.runtime"
> download-size="0"
> install-size="0"
> version="3.3.100.v20070530"
> unpack="false"/>
> <plugin
> id="org.eclipse.equinox.common"
> download-size="0"
> install-size="0"
> version="3.3.0.v20070426"
> unpack="false"/>
> <plugin
> id="org.eclipse.equinox.http.registry"
> download-size="0"
> install-size="0"
> version="1.0.100.v20071203"
> unpack="false"/>
> <plugin
> id="org.eclipse.equinox.http.servlet"
> download-size="0"
> install-size="0"
> version="1.0.100.v20080201"
> unpack="false"/>
> <plugin
> id="org.eclipse.equinox.preferences"
> download-size="0"
> install-size="0"
> version="3.2.100.v20070522"
> unpack="false"/>
> <plugin
> id="org.eclipse.equinox.registry"
> download-size="0"
> install-size="0"
> version="3.3.1.R33x_v20070802"
> unpack="false"/>
> <plugin
> id="org.eclipse.osgi"
> download-size="0"
> install-size="0"
> version="3.3.1.R33x_v20070828"
> unpack="false"/>
> <plugin
> id="org.eclipse.osgi.services"
> download-size="0"
> install-size="0"
> version="3.1.200.v20070605"
> unpack="false"/>
> <plugin
> id="org.eclipse.rap.jface"
> download-size="0"
> install-size="0"
> version="1.1.0.20080220-1610"
> unpack="false"/>
> <plugin
> id="org.eclipse.rap.rwt"
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> id="org.eclipse.rap.ui.workbench"
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> id="org.eclipse.update.configurator"
> download-size="0"
> install-size="0"
> version="3.2.101.R33x_v20070810"
> unpack="false"/>
> <plugin
> id="org.eclipse.core.expressions"
> download-size="0"
> install-size="0"
> version="3.3.0.v20070606-0010"
> unpack="false"/>
> <plugin
> id="org.eclipse.equinox.app"
> download-size="0"
> install-size="0"
> version="1.0.1.R33x_v20070828"
> unpack="false"/>
> <plugin
> id="org.eclipse.rap.ui"
> download-size="0"
> install-size="0"
> unpack="false"/>
> </feature>
Re: Servlet delegate not registered without javax.servlet plugins [message #79118 is a reply to message #78789] |
Mon, 24 March 2008 15:04   |
Originally posted by: fappel.innoopract.com
did you look up the .log file in the webapp's work directory (example:
<tomcat root dir>\work\Catalina\localhost\<your
app>\eclipse\workspace\.metadata\.log) for more infos?
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: nicolas lavoillotte [mailto:n.lavoillotte@educagri.fr]
Bereitgestellt: Freitag, 21. März 2008 09:38
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Servlet delegate not registered without javax.servlet
plugins
Betreff: Servlet delegate not registered without javax.servlet plugins
> Hi all
> I'm using RAP extention (1.1.0_M1) with eclipse Europa 3.3 My project
> and when I run my browser :
> Tomacat says :
> n'est pas disponible.
references :
nox.
nox.
r/org.
> e.feature
> best regards
<feature
> </description>
> </copyright>
> </license>
> <plugin
> id="FNPL_etat"
> download-size="0"
> install-size="0"
> version="1.0.0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> version="1.0.0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> <plugin
> download-size="0"
> install-size="0"
> unpack="false"/>
> </feature>
Re: Servlet delegate not registered without javax.servlet plugins [message #79313 is a reply to message #79118] |
Wed, 26 March 2008 12:44  |
Le Mon, 24 Mar 2008 20:04:37 +0100, Frank Appel a écrit:
Hi frank,
thanks for your response,
I didn't know this log file and it can help me in the future.
Now I found why my app didn't run, the servletbridge bundle was missing !
regards
nicolas
> Ciao
> Frank
> plugins
>> Hi all
>> Tomacat says :
> references :
> nox.
> nox.
> r/org.
>> e.feature
>> best regards
> <feature
>> </description>
>> </copyright>
>> </license>
>> <plugin
>> id="FNPL_etat"
>> download-size="0"
>> install-size="0"
>> version="1.0.0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> version="1.0.0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> <plugin
>> download-size="0"
>> install-size="0"
>> unpack="false"/>
>> </feature>
Current Time: Mon Jul 21 21:47:24 EDT 2025
Powered by FUDForum. Page generated in 0.04805 seconds
