Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Possible bug with Buckminster/subversive integration.
Re: [buckminster-dev] Possible bug with Buckminster/subversive integration. [message #7050] Thu, 06 March 2008 14:05
Hi Scott,
you're right. We need to catch up with Subversive API changes. Please
submit a bugzilla for this.
Thomas Hallgren
Scott, Rich wrote:
> I think I have found an incompatibility between the Buckminster
> subversive integration and the current Subversive plugin available
> from eclipse.org. I’m new to Buckminster, so before posting it as a
> bug I wanted to check and see if I am likely correct.
> I have installed the late Buckminster along with the subversive
> integration. I already had subversive 0.7 and its associated
> requirements installed and operational. Buckminster operations that do
> not use svn appear to be working fine.
> I’m trying the Hello_XML_World example. I open
> http://www.eclipse.org/buckminster/samples/queries/demo.cque ry and the
> cquery is displayed. When I push the “Resolve To Wizard” button, I get
> the following error:
> java.lang.NoSuchMethodError:
> org.eclipse.team.svn.core.utility.SubProgressMonitorWithInfo . <init>(Lorg/eclipse/core/runtime/IProgressMonitor;I)V
> ERROR [0001] : java.lang.NoSuchMethodError:
> Checking the 0.7 source for
> org.eclipse.team.svn.core.utility.SubProgressMonitorWithInfo , the
> constructor has been changed to take a double, rather than the int
> listed in the error message. Best I can tell, 0.7 is the earliest
> subversive version available on the eclipse site (1.1 (an older
> version) is available on the polarion site, but I have not found the
> other required plugins to match).
> I looks like the Buckminster integration code that is calling
> org.eclipse.team.svn.core.utility.SubProgressMonitorWithInfo needs to
> be updated to pass a double.
> Does assessment make sense? If so, I can submit a bug report.
> Thanks
> Rich Scott
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] Possible bug with Buckminster/subversive integration.
Next Topic:RE: [buckminster-dev] Possible bug withBuckminster/subversive integration.
Current Time: Sun Jul 13 15:03:58 EDT 2025
Powered by FUDForum. Page generated in 0.04542 seconds
