Home » Eclipse Projects » Remote Application Platform (RAP) » Table alignments - set different alignments on a single column
Table alignments - set different alignments on a single column [message #78758] Wed, 19 March 2008 13:07 Go to next message
does anyone knows if is it possible to give different alignments to a
table header column and to the records on that column? Example, the
header column text be set with a SWT.LEFT alignment and the records on
that column be set with a SWT.RIGHT alignment.
Currently TableColumn only has a setAllignment(int) that defines the
alignment for all information on the column (header + data). Is it
possible, in same way, to give separate alignments to a single column?
I'm using label providers and table viewers to interact with the table.
Don't know if this helps with something...
Thanks in advance,
Hugo Ferreira
Re: Table alignments - set different alignments on a single column [message #78907 is a reply to message #78758] Sun, 23 March 2008 10:42 Go to previous message
Hi Hugo,
as far as I can see that is even in SWT not possible besides
owner-drawing cells. So there will be no support in RAP as long as this
is not possible in SWT without owner-drawing the cells.
Greets
Benny
Hugo Ferreira wrote:
> a table header column and to the records on that column? Example, the
> Thanks in advance,
> Hugo Ferreira
Previous Topic:Problems with event enqueueing and client-server synchronization
Next Topic:Servlet delegate not registered without javax.servlet plugins
Current Time: Tue Jun 10 03:30:23 EDT 2025
Powered by FUDForum. Page generated in 0.05060 seconds
