Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo]Custom primary key column is not being defined correctly.
[Teneo]Custom primary key column is not being defined correctly. [message #78746] |
Fri, 06 April 2007 14:41  |
Hi Martin,
According to the page http://www.elver.org/hibernate/ejb3_features.html:
When an eattribute has its ID property set to true and there is no @Id
annotated eattribute in the eclass then the ID eattribute is used. This
default behavior can be changed using the option: ID_FEATURE_AS_PRIMARY_KEY.
When I follow the instructions above and set the ID property (and I don't
set the option), I get a mapping of the form:
<id name="id" type="long">
<column not-null="true" unique="false" name="`id`"/>
</id>
But this mapping does not generate the primary key (and does not set the
unique constraint).
Back in Teneo v200610261350, it generated the mapping below which works
fine.
I am not sure in which specific Teneo version introduced the problem.
<id name="id" type="long" column="`ID`">
<generator class="native"/>
</id>
Let me know if this is a bug or if there is some other setting that I am
missing.
Attached is a plugin (like the others) that duplicates this problem - it
throws a NonUniqueObjectException.
-mike
Re: [Teneo]Custom primary key column is not being defined correctly. [message #78778 is a reply to message #78764] |
Fri, 06 April 2007 16:14   |
Hi Mike,
Good that you provided an easy to reproduce test case. The issue is not with the option.
First I would say that the column tag should have unique="true", so this seems a mistake in the
mapping but this mistake does not seem to give a problem.
I tested this with both hsqldb and mysql. With mysql a primary key is created (I tested two sql
insert statements with the same id and the second one failed). The value of the unique="true|false"
attribute (the mapping mistake I mention above) did not make a difference, for both true and false I
got a pk.
Testing using hsqldb showed that I could not insert an object with the same id twice (got:
java.sql.BatchUpdateException: failed batch). So I assume that also hsqldb creates a pk (at least
with me).
When I run the testcase as you send me I get the following nonuniqueobjectexception:
Caused by: org.hibernate.NonUniqueObjectException: a different object with the same identifier value
was already associated with the session: [StringCollection#0]
Afaiu this is not related to a database constraint violation, it happens earlier (before the
database inserts take place) as hibernate already notices that two objects with the same id are
associated with the session. This seems a correct exception as there are two objects with the same
id (0 in your case) associated with the session.
gr. Martin
Christian Donhofer wrote:
> On Fri, 06 Apr 2007 13:41:24 -0500 Michael Kanaley wrote:
>> Hi Martin,
> hi michael,
> please output your persistenceoptions and post them here - maybe the
> feature isn't set to true by default anymore?
> chris
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]Custom primary key column is not being defined correctly. [message #78886 is a reply to message #78778] |
Sun, 08 April 2007 06:28   |
Hi Martin,
I agree that unique="false" is not a major problem, although I think the
default should be changed to unique="true" - should I file a bugzilla?
The real problem I am having is that in Teneo v200610261350, a primary key
generator was automatically being inserted into the id mapping like:
In the latest Teneo, this no longer happens but I would like it to.
Is there a way to make this happen?
-mike
"Martin Taal" <mtaal@elver.org> wrote in message
news:ev69nk$79o$1@build.eclipse.org...
> Hi Mike,
> with the option.
> seems a mistake in the mapping but this mistake does not seem to give a
> problem.
> created (I tested two sql insert statements with the same id and the
> second one failed). The value of the unique="true|false" attribute (the
> and false I got a pk.
> same id twice (got: java.sql.BatchUpdateException: failed batch). So I
> assume that also hsqldb creates a pk (at least with me).
> the same identifier value was already associated with the session:
> earlier (before the database inserts take place) as hibernate already
> notices that two objects with the same id are associated with the session.
> This seems a correct exception as there are two objects with the same id
> gr. Martin
>>> Hi Martin,
>> hi michael,
>> chris
> The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #78898 is a reply to message #78886] |
Sun, 08 April 2007 16:31   |
Hi Mike,
I have already changed the behavior to unique=true (for the 0,8,0 build) and have added a bugzilla
for this.
No there is currently no way to let Teneo automatically create the generator tag for an id. One way
is to use an edatatype for the id attributes and set a generator annotation on the edatatype.
I also thought about automatic adding this behavior (option driven) to id attributes of type long.
If you are interested can you enter a bugzilla for this?
gr. Martin
> Hi Martin,
> -mike
>> Hi Mike,
>> with the option.
>> problem.
>> gr. Martin
>>>> Hi Martin,
>>> hi michael,
>>> chris
>> The Netherlands
The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #78936 is a reply to message #78898] |
Mon, 09 April 2007 13:43   |
Filed 181631. I am also experimenting using EDataTypes to set the generator.
-mike
news:evbjg1$ujj$1@build.eclipse.org...
> Hi Mike,
> and have added a bugzilla for this.
> generator tag for an id. One way is to use an edatatype for the id
> attributes of type long. If you are interested can you enter a bugzilla
> for this?
> gr. Martin
>> Hi Martin,
>> the default should be changed to unique="true" - should I file a
>> bugzilla?
>> key generator was automatically being inserted into the id mapping like:
>> Thanks,
>> -mike
>>> Hi Mike,
>>> with the option.
>>> problem.
>>> true and false I got a pk.
>>> with the same identifier value was already associated with the session:
>>> the same id (0 in your case) associated with the session.
>>> gr. Martin
>>>>> Hi Martin,
>>>>> This default behavior can be changed using the option:
>>>> hi michael,
>>>> chris
>>> The Netherlands
> The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #78964 is a reply to message #78936] |
Tue, 10 April 2007 00:11   |
I saw it.
btw, the reason that I mention EDataTypes is that then you don't need to add the annotation on each
EAttribute but can maintain them in one location (the EDataType). The annotations on EDataType also
work on EAttributes (and vice versa).
gr. Martin
> -mike
>> Hi Mike,
>> for this?
>> gr. Martin
>>> Hi Martin,
>>> bugzilla?
>>> Thanks,
>>> -mike
>>>> Hi Mike,
>>>> with the option.
>>>> problem.
>>>> gr. Martin
>>>>>> Hi Martin,
>>>>> hi michael,
>>>>> chris
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #79498 is a reply to message #78964] |
Wed, 11 April 2007 17:50   |
Hi Martin,
I defined an EDataType and assigned it the following annotations:
@Id
@GeneratedValue(generator="IdentitySeq")
@SequenceGenerator(name="IdentitySeq",sequenceName="IDENTITY_SEQ ")
@Column(unique="true")
when I did this, my attribute of this EDataType got mapping:
<id name="id" type="java.lang.Long">
<column not-null="false" unique="true" name="`id`"/>
</id>
Is that right?
I like the mapping, I don't care about the annotations.
I am just not sure about the most concise way of defining the annotations to
achieve this mapping.
If you know offhand, that would help me.
Thanks for all the help,
-mike
news:evf2on$ui3$1@build.eclipse.org...
>I saw it.
> add the annotation on each EAttribute but can maintain them in one
> location (the EDataType). The annotations on EDataType also work on
> gr. Martin
>> generator.
>> Thanks,
>> -mike
>>> Hi Mike,
>>> id attributes of type long. If you are interested can you enter a
>>> bugzilla for this?
>>> gr. Martin
>>>> Hi Martin,
>>>> bugzilla?
>>>> like:
>>>> Thanks,
>>>> -mike
>>>>> Hi Mike,
>>>>> this seems a mistake in the mapping but this mistake does not seem to
>>>>> give a problem.
>>>>> both true and false I got a pk.
>>>>> happens earlier (before the database inserts take place) as hibernate
>>>>> already notices that two objects with the same id are associated with
>>>>> with the same id (0 in your case) associated with the session.
>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> @Id annotated eattribute in the eclass then the ID eattribute is
>>>>>>> used. This default behavior can be changed using the option:
>>>>>> hi michael,
>>>>>> chris
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #79511 is a reply to message #79498] |
Wed, 11 April 2007 18:11  |
Hi Mike,
These annotations should give the same mapping:
@Id
@GeneratedValue(strategy="AUTO")
Your annotations do not correspond with the mapping. To use the sequencegenerator you need to change
two things:
- define the sequencegenerator ann. on epackage level (support for this on estructuralfeature level
should be added to Teneo, you can enter a bugzilla for this if you want)
- also define a strategy attribute in GeneratedValue, the value should be: strategy="SEQUENCE"
But if the mapping below is allright then you only need to specify the Id and the GeneratedValue
annotations as above.
gr. Martin
> Hi Martin,
> @Id
> </id>
> Is that right?
> -mike
>> I saw it.
>> gr. Martin
>>> generator.
>>> Thanks,
>>> -mike
>>>> Hi Mike,
>>>> bugzilla for this?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> bugzilla?
>>>>> like:
>>>>> Thanks,
>>>>> -mike
>>>>>> Hi Mike,
>>>>>> give a problem.
>>>>>> gr. Martin
>>>>>>>> Hi Martin,
>>>>>>> hi michael,
>>>>>>> chris
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #604449 is a reply to message #78764] |
Hi Mike,
got a pk.
with me).
gr. Martin
>> Hi Martin,
> hi michael,
> chris
The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #604478 is a reply to message #78778] |
Hi Martin,
-mike
> Hi Mike,
> with the option.
> problem.
> gr. Martin
>>> Hi Martin,
>> hi michael,
>> chris
> The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #604482 is a reply to message #78886] |
Hi Mike,
for this.
gr. Martin
> Hi Martin,
> -mike
>> Hi Mike,
>> with the option.
>> problem.
>> gr. Martin
>>>> Hi Martin,
>>> hi michael,
>>> chris
>> The Netherlands
The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #604499 is a reply to message #78898] |
-mike
> Hi Mike,
> for this?
> gr. Martin
>> Hi Martin,
>> bugzilla?
>> Thanks,
>> -mike
>>> Hi Mike,
>>> with the option.
>>> problem.
>>> gr. Martin
>>>>> Hi Martin,
>>>> hi michael,
>>>> chris
>>> The Netherlands
> The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #604513 is a reply to message #78936] |
I saw it.
gr. Martin
> -mike
>> Hi Mike,
>> for this?
>> gr. Martin
>>> Hi Martin,
>>> bugzilla?
>>> Thanks,
>>> -mike
>>>> Hi Mike,
>>>> with the option.
>>>> problem.
>>>> gr. Martin
>>>>>> Hi Martin,
>>>>> hi michael,
>>>>> chris
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #604652 is a reply to message #78964] |
Hi Martin,
@Id
</id>
Is that right?
-mike
>I saw it.
> gr. Martin
>> generator.
>> Thanks,
>> -mike
>>> Hi Mike,
>>> bugzilla for this?
>>> gr. Martin
>>>> Hi Martin,
>>>> bugzilla?
>>>> like:
>>>> Thanks,
>>>> -mike
>>>>> Hi Mike,
>>>>> give a problem.
>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>> hi michael,
>>>>>> chris
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: [Teneo]Custom primary key column is not being defined correctly. [message #604656 is a reply to message #79498] |
Hi Mike,
@Id
two things:
gr. Martin
> Hi Martin,
> @Id
> </id>
> Is that right?
> -mike
>> I saw it.
>> gr. Martin
>>> generator.
>>> Thanks,
>>> -mike
>>>> Hi Mike,
>>>> bugzilla for this?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> bugzilla?
>>>>> like:
>>>>> Thanks,
>>>>> -mike
>>>>>> Hi Mike,
>>>>>> give a problem.
>>>>>> gr. Martin
>>>>>>>> Hi Martin,
>>>>>>> hi michael,
>>>>>>> chris
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
The Netherlands
Current Time: Mon Jul 21 21:34:28 EDT 2025
Powered by FUDForum. Page generated in 0.43791 seconds
