Home » Newcomers » Newcomers » CVS filtered view
CVS filtered view [message #78741] Fri, 17 June 2005 11:38 Go to next message
Originally posted by: sjc.qx.net
Is there a way to show a flat list of modified CVS files in a source tree?
If not, how would I find out if there was any development going on in this
area? I found in the help a way to create a resource filter in plugin.xml
using org.eclipse.ui.ide.resourceFilters. If there is no such CVS filtering
capabliity, I presume one could join the Eclipse development team and write
org.eclipse.ui.ide.cvsFilters. Would this be an appropriate direction to
take?
Steve
Re: CVS filtered view [message #79438 is a reply to message #78741] Tue, 21 June 2005 14:57 Go to previous messageGo to next message
> area?
Have you looked at the Synchronize view? Right-click on a Project (or a
folder/folders) and choose Team > Synchronize. It shows incoming and
outgoing changes and provides the user the ability to see side-by-side
comparison of each changed file.
HTH,
Eric
Re: CVS filtered view [message #80568 is a reply to message #79438] Fri, 24 June 2005 13:58 Go to previous message
That is exactly what I was looking for. Apologies for not doing enough
homework before asking the question.
Steve
"Eric Rizzo" <eclipse@rizzoweb.com> wrote in message
news:d99o2i$26q$1@news.eclipse.org...
>> tree? If not, how would I find out if there was any development going on
>> in this area?
> HTH,
> Eric
Previous Topic:Problem running "Hello World" with SWT (as in Cheat Sheet)
Next Topic:Navigator filtering
Current Time: Sun Jul 27 08:43:24 EDT 2025
Powered by FUDForum. Page generated in 0.06971 seconds
