Home » Archived » Memory Analyzer (MAT) » Save Value to File
Save Value to File [message #7044] Thu, 13 November 2008 19:25 Go to next message
Originally posted by: cgrinds.us.ibm.com
I selected rows from a OQL result set and choose Copy > Save Value to File.
It didn't save what I expected, which was the string column.
This was my query:
SELECT toString(k.key) from objects (SELECT objects outbounds(x.table) FROM
OBJECTS 0x22eab878 x) k
As you can see, my sole column was a string but instead of writing the
string value to the file it wrote the object.
I realize this isn't exactly what SaveValueAsQuery was intended to do but
seems like a reasonable feature.
I looked at adding this option to SaveValueAsQuery but didn't make a lot of
progress since the actual object is an OQLQueryImpl.ResultSet.$1. Seems
like the cleanest way to solve this might be creating a different action
that has more intimate knowledge of OQL. Thoughts?
Chris Grindstaff
cgrinds@us.ibm.com
Re: Save Value to File [message #7067 is a reply to message #7044] Thu, 13 November 2008 20:31 Go to previous messageGo to next message
Chris Grindstaff <cgrinds@us.ibm.com> wrote in
news:Xns9B55C58E11987chrisibm@206.191.52.34:
> File. It didn't save what I expected, which was the string column.
> This was my query:
> FROM OBJECTS 0x22eab878 x) k
Ah I spoke to soon, the same functionality can be achieved using Export >
to TXT.
Chris Grindstaff
cgrinds@us.ibm.com
Re: Save Value to File [message #7090 is a reply to message #7067] Fri, 14 November 2008 03:09 Go to previous message
Hi Chris,
that _is_ confusing:
* Export to Text / CSV etc. look at the table/tree etc.
* Save Value to File looks at the heap object behind the row (the one that
is detailed in the object inspector). It does not care if you actually
display one property in a column...
Andreas.
Previous Topic:Problems checking out src
Next Topic:Minor CSVOutputter patch - 1 attachment
Current Time: Sun Jul 13 22:53:33 EDT 2025
Powered by FUDForum. Page generated in 0.38137 seconds
