Home » Modeling » GMF (Graphical Modeling Framework) » Attaching analysis code
Attaching analysis code [message #78645] Fri, 17 November 2006 14:54 Go to next message
I would like to create a modeling tool in GMF and include some
analysis functionality with that tool. Basically I want a modeler
to be able to select a model element from a model and run a tool
that traverses the model starting with that model element. For
example, a single analysis might be how many model elements are
reachable downstream in four steps. Slightly more complex analyses
might look at weightings, filter by kinds of links, etc.
How should I write that analysis code? Is there a way in GMF or EMF
to write code that gives me the items that a particular model
element links to? Can I call back to the diagram to (for example)
change color of model elements?
Dave
Re: Attaching analysis code [message #78803 is a reply to message #78645] Mon, 20 November 2006 06:39 Go to previous message
Hi Dave,
There is a basic support for writing analysis code.
See http://wiki.eclipse.org/index.php/GMF_Constraints#Metrics
In the current implementation, 'Metrics' action is executed from the
diagram root down the
hierarchy. At the moment, any element selection is not supported.
/Radek
On Fri, 17 Nov 2006 20:54:40 +0100, Dave Bridgeland <bridgeland@yahoo.com>
> that traverses the model starting with that model element. For example,
> to write code that gives me the items that a particular model element
> Dave
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Previous Topic:Semantic v Notation Model
Next Topic:Access to figures through domain model elements
Current Time: Tue Jul 22 01:55:57 EDT 2025
Powered by FUDForum. Page generated in 0.05056 seconds
