Home » Archived » Visual Editor (VE) » Problems with launching VE
| Problems with launching VE [message #78632] |
Tue, 01 February 2005 11:03  |
Originally posted by: bds_development.bdssimulations.co
I've been having problems launching the VE view in Eclipse. After a new
install of Eclipse (and updates for VE) I am able to use VE with no
problems. After some time, the enviroments seems to get corrupted and I
am unable to launch the VE view (Error trying to set new file in editor).
I have attached excerpts from the .log file in my workspace:
!ENTRY org.eclipse.debug.core 4 120 Feb 01, 2005 10:49:31.250
!MESSAGE Launch mode run not supported for configuration type
org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
!ENTRY org.eclipse.ve.java.core 4 16 Feb 01, 2005 10:49:31.328
!STACK 1
org.eclipse.core.runtime.CoreException: Launch mode run not supported for
configuration type org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
org.eclipse.debug.internal.core.LaunchConfigurationType.getD elegate(LaunchConfigurationType.java:221)
org.eclipse.debug.internal.core.LaunchConfiguration.getDeleg ate(LaunchConfiguration.java:360)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:514)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:425)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:295)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:227)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:164)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!SUBENTRY 1 org.eclipse.debug.core 4 120 Feb 01, 2005 10:49:31.328
!STACK 1
I'm not sure if I'm doing something wrong.
Any help would be appreciated.
| Re: Problems with launching VE [message #79117 is a reply to message #78762] |
Fri, 04 February 2005 12:33   |
Dave Saas wrote:
> Rich Kulp wrote:
>> Update to VE 1.0.2. It has many fixes in it. See if that helps.
> Rich,
> I reinstalled Eclipse and then installed VE 1.0.2. Everthing appears to
> be working now, though I never saw the problem immediately after install.
> As one additional note, I was also able to get the VE to run by switching
> the workspace.
> Thanks for your help, I'm hopeful this will resolve my problem.
> Dave
Rich,
After reinstalling Eclipse 3.0.1 and VE 1.0.2, the problem came back.
Still getting the same errors in the .log file (see below). If I create a
new workspace the problem goes away for awhile. Any ideas?
Dave
!ENTRY org.eclipse.ve.java.core 4 16 Feb 04, 2005 12:18:15.468
!STACK 1
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:432)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:299)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:231)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:157)
!SUBENTRY 1 org.eclipse.debug.core 4 120 Feb 04, 2005 12:18:15.468
| Re: Problems with launching VE [message #79131 is a reply to message #79117] |
Fri, 04 February 2005 14:27   |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Not a clue. That's way down in the guts of Eclipse. Somehow your
configuration is being messed up. This is done through plugin.xml and
somehow the information is getting lost. There is nothing we do that
could cause that. Are you doing anything unusual with your Eclipse
installation? Something is screwing it up.
What is your operating system?
Dave Saas wrote:
> Dave Saas wrote:
>> Rich,
>> to be working now, though I never saw the problem immediately after
>> install. As one additional note, I was also able to get the VE to run
>> by switching the workspace.
>> Dave
> Rich,
> a new workspace the problem goes away for awhile. Any ideas?
> Dave
> !STACK 1
Rich Kulp
| Re: Problems with launching VE [message #79286 is a reply to message #79131] |
Mon, 07 February 2005 07:50   |
Rich,
I'm running on Windows XP Pro, SP 2. As far as the Eclispe confiugration,
I'm not doing anything strange that I know of, I've followed the Eclipse
and VE installation instructions.
Dave
> Dave Saas wrote:
>> Dave Saas wrote:
>>> Rich,
>>> Dave
>> Rich,
>> Thanks,
>> Dave
>> !STACK 1
| Re: Problems with launching VE [message #79414 is a reply to message #79286] |
Tue, 08 February 2005 00:09  |
Originally posted by: jtbonin.gmail.com
Dave Saas wrote:
> Rich,
> Dave
Hi Dave,
I was having very similar issues, also running on Win XP Pro SP2. I found
that turning off my Norton Antivirus Auto-Protect resolved all of the
problems I was having. I can only guess that it was interfering with the
writing of the configuration files. It worked for me...
Jeff
>> Dave Saas wrote:
>>> Dave Saas wrote:
>>>> Rich,
>>>> Dave
>>> Rich,
>>> Thanks,
>>> Dave
>>> !STACK 1
| Re: Problems with launching VE [message #604912 is a reply to message #78632] |
Tue, 01 February 2005 12:40  |
You shouldn't be getting this. I wonder, did you use the update manager
to get up to 1.0.2 and then use the manage configurations to uninstall
1.0.1.1? If you did that would mess things up and may result in an error
like this. There is a bug in 3.0.1 Eclipse with the update manager that
the uninstall of ve exposes. It has been fixed in 3.1.
Rich Kulp
| Re: Problems with launching VE [message #604916 is a reply to message #78693] |
Tue, 01 February 2005 13:31  |
Rich,
Thanks for the quick response. I installed Eclipse 3.0.1, and then
installed VE 1.0.1 with the update manager. I haven't used the "manage
configurations" to do anything. Additionally, I have VE SDK 1.0.1, EMF
SDK 2.01, and GEF SDK 3.01 installed (all through the update manager).
Anything else I can look for?
Dave
| Re: Problems with launching VE [message #604927 is a reply to message #78719] |
Wed, 02 February 2005 09:15  |
Rich,
the workspace.
Dave
| Re: Problems with launching VE [message #604988 is a reply to message #78762] |
Dave Saas wrote:
> Rich,
> the workspace.
> Dave
Rich,
Dave
!STACK 1
| Re: Problems with launching VE [message #604991 is a reply to message #79117] |
Dave Saas wrote:
> Dave Saas wrote:
>> Rich,
>> Dave
> Rich,
> Dave
> !STACK 1
Rich Kulp
| Re: Problems with launching VE [message #605034 is a reply to message #79131] |
Rich,
Dave
> Dave Saas wrote:
>> Dave Saas wrote:
>>> Rich,
>>> Dave
>> Rich,
>> Thanks,
>> Dave
>> !STACK 1
| Re: Problems with launching VE [message #605049 is a reply to message #79286] |
Mon, 07 February 2005 14:07  |
I'm afraid I can't help you then. We do nothing with the launching
configuration type. That is all buried deep down in the bowels of
Eclipse. They maintain it.
Rich Kulp
| Re: Problems with launching VE [message #605061 is a reply to message #79286] |
Dave Saas wrote:
> Rich,
> Dave
Hi Dave,
Jeff
>> Dave Saas wrote:
>>> Dave Saas wrote:
>>>> Rich,
>>>> Dave
>>> Rich,
>>> Thanks,
>>> Dave
>>> !STACK 1
Current Time: Thu Nov 20 19:27:38 EST 2025
Powered by FUDForum. Page generated in 0.06807 seconds
