Home » Language IDEs » PHP Development Tools (PDT) » org.eclipse.php.ui.PHPCompletionProposalComputer crash
org.eclipse.php.ui.PHPCompletionProposalComputer crash [message #78615] |
Tue, 19 August 2008 19:39  |
Originally posted by: awjrichards.gmail.com
--------------020206050905070006030101
I have 64-bit Eclipse PDT working with Ganymede under 64-bit Ubuntu
8.04. Whenever I try to create a PHP variable (typing '$'), Eclipse
freezes for a while - maybe 20 - 60 seconds. Occasionally, it will
display the following error:
"The 'org.eclipse.php.ui.PHPCompletionProposalCOmputer' proposal
computer from the 'org.eclipse.php.ui' plug-in did not complete
normally. The extension took too long to return from the
'computeCompletionProposals()' operation."
I have attached a screenshot. I've tried disabling all of the options
under the PHP->Editor->Code Assist pane in my preferences, which seems
to prevent any freezing, although performance is choppy - meaning
Eclipse will periodically hang for a second or two while I'm typing (I
can't detect any kind of pattern to it) or moving the cursor around.
I dunno if it'll make any difference, but I'm starting Eclipse with this
command: /usr/bin/eclipse64 -vmargs -Xmx512M.
Anybody have any ideas how to get around this? I'm also attaching my
error log.
Thanks so much!
Arthur Richards
name="eclipse_error_log.log"
Content-Disposition: inline;
filename="eclipse_error_log.log"
!SESSION 2008-08-19 09:41:41.113 -----------------------------------------------
eclipse.buildId=I20080617-2000
java.version=1.6.0_06
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
This is a continuation of log file /home/arthur/Dev/.metadata/.bak_0.log
Created Time: 2008-08-19 09:59:43.047
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 09:59:43.047
!MESSAGE Unexpected runtime error while computing a text hover
!STACK 0
at org.eclipse.ui.texteditor.ChainedPreferenceStore.getVisibleS tore(ChainedPreferenceStore.java:529)
at org.eclipse.ui.texteditor.ChainedPreferenceStore.getBoolean( ChainedPreferenceStore.java:171)
at org.eclipse.dltk.internal.ui.text.hover.AbstractAnnotationHo ver.isActive(AbstractAnnotationHover.java:135)
at org.eclipse.dltk.internal.ui.text.hover.AbstractAnnotationHo ver.getHoverInfo(AbstractAnnotationHover.java:95)
at org.eclipse.php.internal.ui.editor.hover.BestMatchHover.getH overInfo(Unknown Source)
at org.eclipse.php.internal.ui.editor.hover.PHPTextHoverProxy.g etHoverInfo(Unknown Source)
at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextView erHoverManager.java:168)
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:02:55.471
!STACK 0
!ENTRY org.eclipse.search 4 0 2008-08-19 10:04:00.190
!MESSAGE Problems encountered during text search.
!SUBENTRY 1 org.eclipse.search 4 4 2008-08-19 10:04:00.190
!MESSAGE File 'berewarding/berewarding/log/frontend_dev.log' has been skipped, problem while reading: ('Resource is out of sync with the file system: '/berewarding/berewarding/log/frontend_dev.log'.').
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource is out of sync with the file system: '/berewarding/berewarding/log/frontend_dev.log'.
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:619)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:298)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:287)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er$FileCharSequence.getInputStream(FileCharSequenceProvider. java:282)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er$FileCharSequence.initializeReader(FileCharSequenceProvide r.java:276)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er$FileCharSequence.reset(FileCharSequenceProvider.java:268)
at org.eclipse.search.internal.core.text.FileCharSequenceProvid er.newCharSequence(FileCharSequenceProvider.java:40)
at org.eclipse.search.internal.core.text.TextSearchVisitor.proc essFile(TextSearchVisitor.java:255)
at org.eclipse.search.internal.core.text.TextSearchVisitor.proc essFiles(TextSearchVisitor.java:190)
at org.eclipse.search.internal.core.text.TextSearchVisitor.sear ch(TextSearchVisitor.java:171)
at org.eclipse.search.internal.core.text.TextSearchVisitor.sear ch(TextSearchVisitor.java:183)
at org.eclipse.search.core.text.TextSearchEngine$1.search(TextS earchEngine.java:54)
at org.eclipse.search.internal.ui.text.FileSearchQuery.run(File SearchQuery.java:184)
at org.eclipse.search2.internal.ui.InternalSearchUI$InternalSea rchJob.run(InternalSearchUI.java:94)
!SUBENTRY 2 org.eclipse.core.resources 4 274 2008-08-19 10:04:00.190
!MESSAGE Resource is out of sync with the file system: '/berewarding/berewarding/log/frontend_dev.log'.
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:04:25.115
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:04:36.090
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:04:46.097
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:06:17.167
!STACK 0
!ENTRY org.eclipse.jface 2 0 2008-08-19 10:38:50.387
!MESSAGE Ignored reentrant call while viewer is busy. This is only logged once per viewer instance, but similar calls will still be ignored.
!STACK 0
java.lang.RuntimeException
at org.eclipse.jface.viewers.ColumnViewer.checkBusy(ColumnViewe r.java:763)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:541)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider$4.run(ScriptExplorerContentProvider.java:1078)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.runUpdates(ScriptExplorerContentProvider.java:180)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.executeRunnables(ScriptExplorerContentProvider.java :141)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.elementChanged(ScriptExplorerContentProvider.java:1 30)
at org.eclipse.dltk.internal.core.DeltaProcessor$3.run(DeltaPro cessor.java:1660)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.dltk.internal.core.DeltaProcessor.notifyListener s(DeltaProcessor.java:1646)
at org.eclipse.dltk.internal.core.DeltaProcessor.firePostChange Delta(DeltaProcessor.java:1490)
at org.eclipse.dltk.internal.core.DeltaProcessor.fire(DeltaProc essor.java:1464)
at org.eclipse.dltk.internal.core.ModelOperation.run(ModelOpera tion.java:751)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.dltk.core.DLTKCore.run(DLTKCore.java:1336)
at org.eclipse.dltk.core.DLTKCore.setBuildpathContainer(DLTKCor e.java:1977)
at org.eclipse.php.internal.core.language.LanguageModelInitiali zer.initialize(Unknown Source)
at org.eclipse.dltk.internal.core.ModelManager.initializeContai ner(ModelManager.java:1684)
at org.eclipse.dltk.internal.core.ModelManager$8.run(ModelManag er.java:1629)
at org.eclipse.dltk.internal.core.ModelManager.initializeAllCon tainers(ModelManager.java:1638)
at org.eclipse.dltk.internal.core.ModelManager.getBuildpathCont ainer(ModelManager.java:1508)
at org.eclipse.dltk.core.DLTKCore.getBuildpathContainer(DLTKCor e.java:1674)
at org.eclipse.dltk.internal.ui.scriptview.BuildPathContainer.<init >(BuildPathContainer.java:91)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.getProjectFragments(ScriptExplorerContentProvider.j ava:369)
at org.eclipse.dltk.internal.ui.StandardModelElementContentProv ider.getChildren(StandardModelElementContentProvider.java:16 3)
at org.eclipse.dltk.internal.ui.navigator.ScriptExplorerContent Provider.getChildren(ScriptExplorerContentProvider.java:307)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1352)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:385)
at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChil dren(AbstractTreeViewer.java:636)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:602)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:799)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1442)
at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:927)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1453)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:126)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1182)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1167)
at org.eclipse.swt.widgets.Tree.gtk_test_expand_row(Tree.java:2 026)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1572)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4105 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:57 83)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1177)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1541)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3031)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 10:41:10.475
!STACK 0
!ENTRY org.eclipse.equinox.p2.director 2 0 2008-08-19 11:25:52.622
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:25:52.622
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.ui 1.0.305.v200802142230 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common.ui 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common.ui 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.edit.ui/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.common 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.ui.ide/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.ui/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.core.runtime/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.search/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.jface.text/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui 1.1.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.ui.workbench.texteditor/[3.2.0,3.4.0 ).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.106.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200806252211 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee 1.1.107.v200803071930 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.codegen/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.core 1.1.203.v200802140626 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core 1.1.101.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.runtime/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core 1.1.101.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core 1.1.101.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.expressions/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emf 1.1.104.v200709131115 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:25:52.623
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.facesconfig 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.facesconfig 1.0.1.v20070912 to requiredCapability: osgi.bundle/org.eclipse.emf.edit.ui/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.core 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.core 1.1.104.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.frameworks 1.1.102.v200709122200 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.frameworks 1.1.102.v200709122200 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emfworkbench.integration 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emfworkbench.integration 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jem 2.0.100.v200709051030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.3.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.frameworks 1.1.103.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.annotations.controller 1.1.2.v200708301745 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.web 1.1.103.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.environment 1.0.200.v200705302225 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200803242054 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200803242054 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200803242054 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200806261300 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200806261300 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.3.v200806261300 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.2.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.2.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jee 1.0.2.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.common.annotations.core 1.1.2.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.jca 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.jca 1.1.105.v200802192030 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env 1.0.205.v200710161954 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env 1.0.205.v200710161954 to requiredCapability: osgi.bundle/org.eclipse.ant.core/[3.1.100,3.2.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env.ui 1.0.203.v200709052219 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws 1.0.204.v200711140435 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsdl 1.1.101.v200801152132 to requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsdl 1.1.101.v200801152132 to requiredCapability: osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.ui 1.0.203.v200708222126 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.ui 1.0.203.v200708222126 to requiredCapability: osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsi 1.0.105.v200706120315 to requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.xsd.core 1.1.202.v200710011705 to requiredCapability: osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
!SESSION 2008-08-19 11:26:53.344 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 1 2008-08-19 11:27:06.680
!MESSAGE NLS unused message: EditVariableEntryDialog_filename_empty in: org.eclipse.dltk.internal.ui.wizards.NewWizardMessages
!ENTRY org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.483
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.483
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.jsf.core 1.0.2.v200802201120 to requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0)..
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.484
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.485
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.489
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2008-08-19 11:28:28.490
!SESSION 2008-08-19 11:30:53.672 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 1 2008-08-19 11:31:06.102
!SESSION 2008-08-19 11:46:28.136 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2008-08-19 11:46:45.068
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.osgi 2 1 2008-08-19 11:46:53.835
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 12:07:03.351
!STACK 0
!ENTRY org.eclipse.jface.text 4 0 2008-08-19 12:07:04.734
!STACK 0
!SESSION 2008-08-19 13:33:05.208 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2008-08-19 13:33:08.431
!ENTRY org.eclipse.osgi 2 1 2008-08-19 13:33:15.768
!ENTRY org.eclipse.dltk.ui 2 0 2008-08-19 13:36:27.114
!MESSAGE The 'org.eclipse.php.ui.PHPCompletionProposalComputer' proposal computer from the 'org.eclipse.php.ui' plug-in did not complete normally. The extension took too long to return from the 'computeCompletionProposals()' operation.
!ENTRY org.eclipse.ui.workbench 2 0 2008-08-19 13:36:27.573
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-08-19 13:36:27.573
!MESSAGE Conflict for 'org.eclipse.ui.navigate.forwardHistory':
HandlerActivation(commandId=org.eclipse.ui.navigate.forwardH istory,
handler=ActionHandler(org.eclipse.ui.internal.NavigationHistoryAction@38a09316),
expression=ActiveShellExpression(Shell {PHP - rncwc/metrics.php - Eclipse SDK}),sourcePriority=17408)
handler=ActionHandler(org.eclipse.ui.internal.dialogs.Prefer encePageHistory$2@3618a665),
expression=ActiveShellExpression(Shell {Preferences}),sourcePriority=17408)
!MESSAGE Conflict for 'org.eclipse.ui.navigate.backwardHistory':
HandlerActivation(commandId=org.eclipse.ui.navigate.backward History,
handler=ActionHandler(org.eclipse.ui.internal.dialogs.Prefer encePageHistory$1@c544ca2),
handler=ActionHandler(org.eclipse.ui.internal.NavigationHistoryAction@72732600),
!ENTRY org.eclipse.ui 4 0 2008-08-19 13:38:49.278
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.OutOfMemoryError: GC overhead limit exceeded)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
at java.lan
Re: org.eclipse.php.ui.PHPCompletionProposalComputer crash [message #92432 is a reply to message #78615] |
Fri, 30 January 2009 07:11  |
We're getting this error on various machines now and it's making Eclipse
unusable. Eclipse will freeze as you're typing, and stay locked for around
30-60 seconds, haven't measured it exactly.
Error message:
"The 'org.eclipse.php.ui.PHPCompletionProposalComputer' proposal computer
Extension took too long to return from the 'computeCompletionProposals()'
operation."
So far I've seen it on Eclipse 3.4 + PDT 2.0 under XP 32-bit, and Eclipse
3.4 + PDT 2.0 under Ubuntu 64-bit.
The XP install was from the PDT all-in-one. The only other plugins active
are Subclipse and YamlEditor.
Current Time: Tue Jul 22 14:48:21 EDT 2025
Powered by FUDForum. Page generated in 0.24926 seconds
