Home » Eclipse Projects » Equinox » help with access restriction on org.eclipse.osgi
help with access restriction on org.eclipse.osgi [message #78543] Wed, 06 December 2006 06:53 Go to next message
Originally posted by: Fabio.Plachetta.cas.de
I get the following error in eclipse, when I try to user a
ServiceTracker or ServiceTrackerCustomizer:
<< Access restriction: The type ServiceTracker is not accessible due to
restriction on required project org.eclipse.osgi >>
I have checked out org.eclipse.osgi from the eclipse-svn.
My Code:
package de.cas.osgi.bundle.opdispatcher.impl;
import org.osgi.framework.BundleActivator;
import org.osgi.framework.BundleContext;
import org.osgi.framework.Constants;
import org.osgi.util.tracker.*;
public class Activator implements BundleActivator {
public static BundleContext context = null;
//error here:
public ServiceTracker tracker;
public void start(BundleContext context) {
What can I do, or what do I do wrong?
TIA
-Fabio
Re: help with access restriction on org.eclipse.osgi [message #78558 is a reply to message #78543] Wed, 06 December 2006 15:29 Go to previous messageGo to next message
Fabio Plachetta wrote:
Do you import org.osgi.util.tracker in your Manifest? This error message
is sometimes caused by either failure to export or failure to import the
package in question.
Harald
Re: help with access restriction on org.eclipse.osgi [message #78624 is a reply to message #78558] Thu, 07 December 2006 05:33 Go to previous message
Hi Harald!
Sometimes the solution is so simple that you just don't see it. Of
course, I forgot to do that! Thanks ;-)
-Fabio
> Harald
Previous Topic:Resource Access in Bundles
Next Topic:Modify Bridge to serve as direct communication channel between tomcat and osgi
Current Time: Fri Jul 25 19:38:17 EDT 2025
Powered by FUDForum. Page generated in 0.04613 seconds
