Home » Language IDEs » PHP Development Tools (PDT) » can't install eclipse PDT with Ganymede
can't install eclipse PDT with Ganymede [message #78521] Mon, 18 August 2008 17:01 Go to next message
Originally posted by: cuco2772.gmail.com
Hi, I've been having problems trying to get this to install.
I followed the directions here:
http://www.howtoforge.com/setting-up-eclipse-pdt2.0-on-eclip se3.4-ganymede
Everything worked fine (except for getting Subeclipse for subversion, but
I can wait on that) up to the point where I downloaded the latest
integration build.
Following the link, I downloaded this .zip file:
org.eclipse.php_feature-I20080722.zip
I unzipped it into a folder inside the eclipse folder called PDT
WHen it unzipped there were 2 additional folders, one called features and
one called plugins. Using the update manager and clicking AddSite->Local
as per the directions, then clicked the feature folder, and then selected
org.eclipse.php_feature_2.0.0.v2XXXXXXXXXXXXX, and I get the message 'no
repository found at ---------------' (that long thing)
Any ideas on what I should do ? Thanks
Re: can't install eclipse PDT with Ganymede [message #78540 is a reply to message #78521] Mon, 18 August 2008 19:11 Go to previous messageGo to next message
Hum, remember that you need to unzip it like: <SOMEWHERE>/eclise_pdt then
inside this folder you will zip folders, wich are this:
eclipse
-- features
-- plugins
So when you add a site, make sure to add "<SOMEWHERE>/eclise_pdt".
> integration build.
Re: can't install eclipse PDT with Ganymede [message #78635 is a reply to message #78540] Tue, 19 August 2008 19:51 Go to previous messageGo to next message
Are you saying I should zip the contents of those folders into a zip file ?
The features directory has another another directory inside it called
org.eclipse.php_feature_2.0.0.v20080722-7H--E7QYGHNHEYY, which inside of
it just has a feature.properties, a feature.xml, a .jpg and a META-INF
directory.
The plugins directory has these:
-rw-r--r-- 1 cuco cuco 3759 2008-07-22 08:09
org.eclipse.php_2.0.0.v20080722.jar
drwxr-xr-x 6 cuco cuco 4096 2008-07-22 08:09
org.eclipse.php.core_2.0.0.v20080722
-rw-r--r-- 1 cuco cuco 396906 2008-07-22 08:08
org.eclipse.php.debug.core_2.0.0.v20080722.jar
-rw-r--r-- 1 cuco cuco 10950 2008-07-22 08:08
org.eclipse.php.debug.daemon_2.0.0.v20080722.jar
-rw-r--r-- 1 cuco cuco 299442 2008-07-22 08:08
org.eclipse.php.debug.ui_2.0.0.v20080722.jar
-rw-r--r-- 1 cuco cuco 3284750 2008-07-22 08:08
org.eclipse.php.help_2.0.0.v20080722.jar
-rw-r--r-- 1 cuco cuco 16229 2008-07-22 08:08
org.eclipse.php.server.core_2.0.0.v20080722.jar
-rw-r--r-- 1 cuco cuco 79683 2008-07-22 08:08
org.eclipse.php.server.ui_2.0.0.v20080722.jar
-rw-r--r-- 1 cuco cuco 1205156 2008-07-22 08:09
org.eclipse.php.ui_2.0.0.v20080722.jar
These look like the right things, but I downloaded the latest
integration build. Maybe I should have downloaded a 'stable' version ?
THanks
Re: can't install eclipse PDT with Ganymede [message #78682 is a reply to message #78635] Wed, 20 August 2008 00:55 Go to previous messageGo to next message
Yep the file is fine but you need to add the folder where you decompress
the zip file, example:
$ cd /tmp
$ mkdir pdt_integration_build
$ cp /home/my_user/org.eclipse.php_feature-I20080722.zip
pdt_integration_build/
$ cd pdt_integration_build
$ unzip org.eclipse.php_feature-I20080722.zip
You decompress the zip in some folder, doesn't care wich folder, you just
need to decompress the zip and add it in Eclipse :D, example:
Help -> Software Updates -> Available Software -> Add Site -> Local
Go to /tmp/pdt_integration_build, press Ok or something and that's all.
> directory.
> THanks
Re: can't install eclipse PDT with Ganymede [message #78929 is a reply to message #78521] Fri, 22 August 2008 22:03 Go to previous message
> and one called plugins. Using the update manager and clicking
> AddSite->Local as per the directions, then clicked the feature folder,
> and then selected
Try setting the Local Site to the "eclipse" folder that unzipping
the file created, or to the file itself as an Archive.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Previous Topic:ADODB autocompletion problem
Next Topic:Selection cannot be launched
Current Time: Sun Aug 31 17:36:19 EDT 2025
Powered by FUDForum. Page generated in 0.04117 seconds
