Home » Language IDEs » ServerTools (WTP) » error in database explorer
error in database explorer [message #78329] Mon, 28 February 2005 17:12
Originally posted by: emerson.tre-sc.gov.br
When trying a insert command i get the following error:
BTW, it would be nice to have a code completion ins SQL scrapbook page and
some templates for common commands.
Detected in Class :
org.eclipse.wst.rdb.server.internal.ui.util.resources.Resour ceLoader
java.util.MissingResourceException: Can't find resource for bundle
java.util.PropertyResourceBundle, key _UI_LABEL_EXECUTION_SUCCESSFUL
at java.util.ResourceBundle.getObject(ResourceBundle.java:326)
at java.util.ResourceBundle.getString(ResourceBundle.java:286)
org.eclipse.wst.rdb.server.internal.ui.util.resources.Resour ceLoader.queryString(ResourceLoader.java:92)
org.eclipse.wst.rdb.server.internal.ui.query.execute.QueryOu tputHelper.runSQLScrapbookQuery(QueryOutputHelper.java:154)
org.eclipse.wst.rdb.internal.sqlscrapbook.views.execute.SQLS crapbookExecuteAction.run(SQLScrapbookExecuteAction.java:62)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:100 3)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:557)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:507)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:462)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1009)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2728)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2427)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Previous Topic:eclipse WTP M3 to SunOne and Weblogic 7
Next Topic:resource files inside WEB-INF/classes
Current Time: Mon Oct 27 14:41:14 EDT 2025
Powered by FUDForum. Page generated in 0.04029 seconds
