| cvsignore problems [message #78231] |
Fri, 18 July 2003 21:48  |
Eclipse doesn't seem to recognize the .cvsignore file in my project
directory.
This causes several effects:
1 - Team | Add to .cvsignore is disabled
2 - Eclipse thinks too much stuff needs to be committed to the
repository : for example, I have a "jars" directory is in .cvsignore,
but Eclipse thinks it's a new add.
cvs from the command line works fine, so I am using that for now.
This problem is occuring in all of my (previously working) projects.
What could be the problem?
With kind regards,
Josh Rehman
citysearch.com
| Re: cvsignore problems [message #78539 is a reply to message #78286] |
Sun, 20 July 2003 15:23  |
Hi Josh,
> It's worth a lot, actually. It tells me that I am neither crazy and
> casts doubt on whether or not my Eclipse installation is damaged.
Have you filed a bug on this yet, or looked to see if there's an
existing one? If not, I'll try to get to it...
-- Laura
FUDForum. Page generated in 0.03625 seconds
