Home » Archived » BIRT » Setting jdbc connection properties when embedding BIRT?
Setting jdbc connection properties when embedding BIRT? [message #78228] |
Fri, 30 September 2005 16:18  |
Is it possible to set JDBC connection properties for a report (eg. url,
user, password,..) when programmatically creating the report and rendering
in an embedded scenario? I know i could achieve this by using scripting in
the report, or by modifying the .rptdesign file before loading it. But
after loading the report, but before running it, can i change the connection
properties? I would like to do this to have the datasource reflect the
environment the report will run against.
Thank you.
Re: Setting jdbc connection properties when embedding BIRT? [message #78440 is a reply to message #78244] |
Mon, 03 October 2005 10:30   |
Thanks for responding Jason.
I would prefer to have general infrastructure that "injects" the correct
environment, rather than every report having to have the same broilerplate
script to set the correct environment. It's a matter of who should be
responsible and control this? Is this a container/environment
responsibility? Or a report responsibility? I would rather reports be a
clean as possible, sticking to rendering responsibilities only.
Marko.
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dhkala$gd8$1@news.eclipse.org...
> Marko,
> Why not just put it in script an have it access either environment
variables
> or a config file for the appropriate environment?
> Jason Weathersby
> BIRT PMC
> "Marko" <mmilicevic@pssd.com> wrote in message
> news:dhk6df$b5g$1@news.eclipse.org...
rendering
> > in
> > connection
> > Thank you.
Re: Setting jdbc connection properties when embedding BIRT? [message #78684 is a reply to message #78440] |
Mon, 03 October 2005 22:36   |
Marko,
This would be some really great functionality to have. It would get
really tedious to have to modify every one of your connection objects to
achive this. In the 2.0 project, things will be a little better in the
sense that you will be able to share your connection objects through the
use of libraries, but injection of control would be a better pattern for
this.
Would you mind creating a bugzilla entry providing any use cases
scenarios that you can think of and any recommended mechanisms for the
injection of the control. Are you thinking something like Spring for this?
Scott Rosenbaum
BIRT PMC
>Marko.
>>Marko,
>variables
>>Jason Weathersby
>>BIRT PMC
>rendering
>>>in
>>>connection
>>>Thank you.
Re: Setting jdbc connection properties when embedding BIRT? [message #79380 is a reply to message #78684] |
Wed, 05 October 2005 14:07   |
Hi Scott. I was speaking about using injection (or IoC) as a general design
pattern. I was not implying any particular mechanism or framework like
Spring.
My use case is embedding BIRT to generate reports. In my case i use the
BIRT API to embed BIRT reports into our web application. Another related
use case would be embedding BIRT in a web app using the BIRT viewer
servlet.
In both cases how does one set environment specific report attributes,
especially datasource configuration?
The most simple solution for me is to just provide an API that allows me to
configure the datasource (from outside of the report).
eg.
IRunAndRenderTask task = engine.createRunAndRenderTask(report);
task.setParameterValues(params);
task.setRenderOption(options);
// now have some Java BIRT API similar to the Javascript ROM API.
task.extensionProperties.odaUser = "<user>";
task.extensionProperties.odaPassword = "<pw>";
task.extensionProperties.odaURL = "<url>";
task.extensionProperties.odaDriverClass = "<driver_class>";
....etc...
There may already be something like this, but i can not find it?
I'm not sure what is the best way to configure/customize the viewer servlet?
Probably the simplest design is to expect people to subclass the servlet.
The subclass could be responsible for configuring and customizing the viewer
using the BIRT Java API. I'm do not think that a more complicated design is
needed, but i'm sure you could also accomplish config/customization using
"extension points", callbacks, AOP, IoC, or some other similar mechanism.
I will add an entry to Bugzilla.
Thanks Scott.
"Scott Rosenbaum" <scottr@innoventsolutions.com> wrote in message
news:dhsprd$deh$2@news.eclipse.org...
> Marko,
> this.
this?
> Scott Rosenbaum
> BIRT PMC
broilerplate
> >Marko.
> >>Marko,
> >variables
> >>Jason Weathersby
> >>BIRT PMC
> >rendering
scripting
> >>>in
> >>>connection
> >>>Thank you.
Re: Setting jdbc connection properties when embedding BIRT? [message #79575 is a reply to message #79380] |
Thu, 06 October 2005 13:32  |
This is functionality that I would like to see as well. My application uses
several different databases that all have the same structure. Our
application decides which database it needs to use, depending on which data
the user is looking at. I'm not sure why all this data was set up to be in
different databases, but that's how our application works. It would be nice
to have a simple way to use one report design file where I could change the
Database URL for a particular datasourse to point to any one of these
databases.
--floor
news:di14jb$j24$1@news.eclipse.org...
> design
> Spring.
> servlet.
> to
> eg.
> ...etc...
> servlet?
> viewer
> is
> Thanks Scott.
>> Marko,
>> this.
> this?
>> Thanks,
>> Scott Rosenbaum
>> BIRT PMC
> broilerplate
>> >a
>> >Marko.
>> >>Marko,
>> >variables
>> >>Jason Weathersby
>> >>BIRT PMC
>> >>>url,
>> >rendering
> scripting
>> >>>in
>> >>>But
>> >>>connection
>> >>>the
>> >>>Thank you.
Current Time: Thu Jul 17 11:55:37 EDT 2025
Powered by FUDForum. Page generated in 0.08841 seconds
