Home » Archived » BIRT » dynamic BIRT ?
dynamic BIRT ? [message #78071] Fri, 30 September 2005 04:23 Go to next message
Originally posted by: newsgroup.cancemi.de
i need to create dynamic reports of MYSQL DB Tables.
The data contains performance measurements.
I searched the whole BIRT site, but i couldn't find a hint if its dynamic
or not.
However, JSP is mentioned and JSP is dynamic :).
1. Is it possible to create a dynamic website f.e. CGI etc., create the
reports dynamically, and link them within the pictures?
2. Does BIRT sum up data f.e. create automatically month based and year
based reports from dayly based?
3. Does BIRT recognize gaps in a data row, f.e. 00:22,00:24,00:25,00:26,
if i mark it as timeline ? the x-axis should be like this
00:22,00:23,00:24,00:25,00:26, the 00:23 value should be set zero or
interpolated. I am asking this, because sometimes measurement data is
missing :(
Ok, i am new to newsgroups. I worked with eclipse but i am new to BIRT.
I tested it, but i couldnt get a good overview, where to create a dynamic
site.
I would be very grateful if you could help me any further.
Ale
Re: dynamic BIRT ? [message #78185 is a reply to message #78071] Fri, 30 September 2005 12:03 Go to previous message
hi Ale,
Its my experience that BIRT is dynamic. You create a report template and
this report template contains information about your data sources. when
the report is ran (server side, or client side) the data sources are
queried and a report is generated for that moment in time.
I think that answers your question. BIRT community correct me if I'm
wrong here.
Ale wrote:
> Hello,
> dynamic or not.
> missing :(
> dynamic site.
> Thanks
> Ale
Previous Topic:PDF "File is already open" error
Next Topic:Getting a class instance from javascript.
Current Time: Sun Aug 31 12:44:45 EDT 2025
Powered by FUDForum. Page generated in 0.03480 seconds
