Home » Archived » EPF » Terminal Server support?
Terminal Server support? [message #7002] Thu, 13 April 2006 07:25 Go to next message
Originally posted by: michel.loehr.saxsys.de
As it looks now, EPF doesn't really support to be used in a terminal
server environment, or does it?
If not, is it on the feature list?
Michel
Re: Terminal Server support? [message #7053 is a reply to message #7002] Thu, 13 April 2006 10:56 Go to previous messageGo to next message
It is not explicitly on the feature list today, but you could submit an
enhancement request in Bugzilla. Could you give us some insight on what
is required to support a terminal server environment?
Thanks.
Michel Löhr wrote:
> Hi
> Cheers,
> Michel
Re: Terminal Server support? [message #7098 is a reply to message #7053] Thu, 13 April 2006 13:25 Go to previous messageGo to next message
For Terminal Server, each user must be able to start the same installed
instance of EPF. Currently, if you start EPF for a second time, you get an
error message.
Michel
Re: Terminal Server support? [message #7117 is a reply to message #7098] Thu, 13 April 2006 13:44 Go to previous message
You can work around this by using parameters for the epf launcher. The
launcher takes the same parameters as an eclipse launcher. If you use
the -data parameter and a unique folder for workspace information you
could run multiple instances of EPF Composer.
For example, each user could have a link on their desktop that has this
command:
\install-location\epf -data \my-home-folder\epfworkspace
Take a look at the parameters in epf.ini in the same folder as the epf
launcher. Any of these can be overridden.
Let me know if this gets you closer to a solution.
Thanks.
> an error message.
> Cheers,
> Michel
Re: Terminal Server support? [message #562403 is a reply to message #7002] Thu, 13 April 2006 10:56 Go to previous message
Thanks.
Michel Löhr wrote:
> Hi
> Cheers,
> Michel
Re: Terminal Server support? [message #562451 is a reply to message #7053] Thu, 13 April 2006 13:25 Go to previous message
error message.
Michel
Re: Terminal Server support? [message #562472 is a reply to message #7098] Thu, 13 April 2006 13:44 Go to previous message
command:
Thanks.
> an error message.
> Cheers,
> Michel
Previous Topic:EPF Composer 1.0-M2-I20060411
Next Topic:Publication
Current Time: Sun Jul 13 21:19:14 EDT 2025
Powered by FUDForum. Page generated in 0.26391 seconds
