Home » Language IDEs » C / C++ IDE (CDT) » C++ PlugIn list
C++ PlugIn list [message #78046] Thu, 07 August 2003 20:59 Go to next message
Originally posted by: david.axter.com
Where can I find a list of plugins for Eclipse?
Are there any good web sites that give instructions for setting up Eclipse
for C++ programming?
Re: C++ PlugIn list [message #78111 is a reply to message #78046] Fri, 08 August 2003 04:44 Go to previous messageGo to next message
Go to www.eclipse.org --> Community --> Projects & plugins.
here u will get all information regarding both opensource and commercial
plugins available for eclipse.
have a look at
1.http://eclipsewiki.swiki.net
2. http://eclipse-plugins.2y.net/eclipse/plugins.jsp
3. http://www.eclipse-workbench.com/jsp/plugins.jsp
4. http://www.crionics.com/products/opensource/eclipse/eclipse. html
5. http://www.jsurfer.org/links.php?op=viewlink&cid=11
Re: C++ PlugIn list [message #78124 is a reply to message #78046] Fri, 08 August 2003 04:44 Go to previous messageGo to next message
have a look at
Re: C++ PlugIn list [message #78173 is a reply to message #78124] Fri, 08 August 2003 15:39 Go to previous messageGo to next message
> have a look at
Thank you for the info. I did find the CDT link, and I'm really surprise
that the CDT link is not accessable from the main site.
I'm trying to get the code complete feature to work. Do you know to work
this feature for C++ files.
Re: C++ PlugIn list [message #78294 is a reply to message #78173] Mon, 11 August 2003 15:04 Go to previous messageGo to next message
This feature will become available as our C++ parser matures.
"Axter" <david@axter.com> wrote in message news:bh0uae$9sv$1@eclipse.org...
Eclipse
> > have a look at
Re: C++ PlugIn list [message #78307 is a reply to message #78294] Tue, 12 August 2003 15:02 Go to previous messageGo to next message
Originally posted by: ashes999.rogers.com
what IS code complete?
"John Camelon" <jcamelon@rational.com> wrote in message
news:bh8p8l$7q3$1@eclipse.org...
commercial
> Eclipse
> > > have a look at
surprise
work
Re: C++ PlugIn list [message #78322 is a reply to message #78307] Tue, 12 August 2003 15:13 Go to previous messageGo to next message
Code Complete AKA Code Assist AKA Command Completion
"Ashiq Alibhai" <ashes999@rogers.com> wrote in message
news:bhbdjl$r0m$1@eclipse.org...
> commercial
> > Eclipse
> > > > have a look at
> surprise
> work
Re: C++ PlugIn list [message #78459 is a reply to message #78307] Wed, 13 August 2003 18:24 Go to previous message
> commercial
> > Eclipse
> > > > have a look at
> surprise
> work
Code complete is when you start to type part of your code, and the
IDE/PlugIn is able to finish it for you via a popup window.
For example, if I've already entered the following:
void SomeFunction()
int QtyEggs = 0;
Know if I type "Qt" the IDE puts a small popup window with "QtyEggs" which
I can then click on to have it finish the rest of the variable.
For VC++ 6.0/7.x there's an AddIn that gives you this feature.
See following link:
http://www.wholetomato.com/
I consider this AddIn to be a benchmark for any code-assit Add-In, and I
hope something like this can be created for eclipse.
I'm thinking of coding it myself, but I first want to see what Add-In's
are already available for Eclipse and what kind of features they have
Previous Topic:Using Updates greater than 1.2.0.9
Next Topic:Code Assist
Current Time: Fri Nov 07 03:09:46 EST 2025
Powered by FUDForum. Page generated in 0.04580 seconds
