eclipse-error Could not find framework [message #77997] |
Wed, 15 June 2005 12:12 |
Originally posted by: k.peschke.gmx.de
i want to start eclipse on a new system. It doesn't work.
The same files and configuration on another system is okay.
!SESSION Wed Jun 15 13:45:25 CEST
2005 -----------------------------------------
!ENTRY org.eclipse.core.launcher 4 0 Jun 15, 2005 13:45:25.765
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:395)
at org.eclipse.core.launcher.Main.basicRun(Main.java:174)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
There in on both systems the same configuration with windowsXP and Eclipse.
thanks for help
Re: eclipse-error Could not find framework [message #78013 is a reply to message #77997] |
Wed, 15 June 2005 12:46 |
Originally posted by: myersj.gmail.com
Klaus,
This usually indicates that the zip file wasn't extracted properly.
Make sure the subfolders are create correctly.
- Jeff
> !STACK
> thanks for help
Re: eclipse-error Could not find framework [message #78028 is a reply to message #78013] |
Wed, 15 June 2005 12:57 |
Jeff,
thanks for your fast answer.
I extracted the zip file on the first system it works and then i copy the
extracted file to the second system. Don' work.
The other way, i extracted the zip file on the second system - don't work -
copy to the first system -it works.
The same result with Eclipse3.1 and Eclipse3.2.
I don't think, there is a failure in the extracted file. But, I start a new
test.
Klaus
"Jeff Myers" <myersj@gmail.com> schrieb im Newsbeitrag
news:d8p800$kvj$1@news.eclipse.org...
> Klaus,
> This usually indicates that the zip file wasn't extracted properly. Make
> - Jeff
Re: eclipse-error Could not find framework [message #78075 is a reply to message #78028] |
Wed, 15 June 2005 14:02 |
Originally posted by: reema.kunar.gmail.com
Hello ,
I am having the same problem in lauching the eclipse.exe.I have my
PATH(system varaible as ) as :
PATH=C:\j2sdk1.4.2_05\bin;C:\opt\eate\watchdog\EXPAT-~1.5\Li bs;C:\WINNT\system32..etc
etc .
JAVA_HOME=C:\j2sdk1.4.2_05\
CLASSPATH=C:\j2sdk1.4.2_05\lib\tools.jar;C:\j2sdk1.4.2_05\li b\dt.jar;
I want to use eclipse 3.0.2 and so i installed it at c:\myProg\Eclipse
previously i had another version at c:\eclipse.
As soon has i click eclipse.exe in the c:\myProg\Eclipse i get a error
which is pasted below:
!SESSION Wed Jun 15 15:27:19 CEST 2005
!ENTRY org.eclipse.core.launcher 4 0 Jun 15, 2005 15:27:19.831
!STACK
Please advice me how to tackle this and start using eclipse.
error problem solved [message #78353 is a reply to message #78075] |
Thu, 16 June 2005 08:05 |
I solved the problem. Thanks Jeff.
The subfolders are incorred, but only on one of my systems.
Why? I use symantec norton commander to unzip and copy the files. Now I used
another unzip and it works.
Norton commander use only big letters. I think, this was the problem.
Reima, you have the same error. Test it also to unzip with another program.
FUDForum. Page generated in 0.03345 seconds
