Home » Language IDEs » PHP Development Tools (PDT) » Debug Error with latest Nightly (N20080810)
Debug Error with latest Nightly (N20080810) [message #77992] Mon, 11 August 2008 13:19 Go to next message
Getting an error with the latest nightly build using Xdebug. Error
occurs when starting a new build using multisession:
An error has occurred. See error log for more details.
org.eclipse.php.internal.debug.core.xdebug.dbgp.model.DBGpMu ltiSessionTarget
cannot be cast to org.eclipse.php.internal.debug.core.model.IPHPDebugTarget
After the error occurs the debug session continues to work. Proccesses
stop when they hit breakpoints and variables are available. The other
problem is that every time a page loads Eclipse reports an error with
"debug output" and the details of "Error". Also getting data in the
Debug Output / Browser Output views when there wasn't data before.
Can do more testing if someone needs more information.
Bug Reported: https://bugs.eclipse.org/bugs/show_bug.cgi?id=243789
Shawn Clark
Re: Debug Error with latest Nightly (N20080810) [message #78026 is a reply to message #77992] Tue, 12 August 2008 04:54 Go to previous messageGo to next message
Hi Shawn, thanks for the bug report. I have fixed the classCastException issue. A new feature of
xdebug support was to use the "Debug Output" and "Browser Output" views. But as you have discovered
there seems to be some sort of issue with the "Debug Output" view.
To supress these errors for now you can turn off output capture for stdout in the xdebug preferences.
Dave Kelsey
Shawn Clark wrote:
> Shawn Clark
Re: Debug Error with latest Nightly (N20080810) [message #78042 is a reply to message #78026] Tue, 12 August 2008 13:39 Go to previous message
Dave,
Thanks for the quick response. I like the idea of getting some
additional information through the Debug / Browser output windows as
well as the option to turn it on / off. I will try it out when I get the
next nightly.
Shawn
> issue. A new feature of xdebug support was to use the "Debug Output" and
> "Browser Output" views. But as you have discovered there seems to be
> Regards
> Dave Kelsey
> Shawn Clark wrote:
>> cannot be cast to
>> Shawn Clark
Previous Topic:UI oddities in preferences
Next Topic:Re: php support install woes - Ganymeade
Current Time: Thu Nov 06 03:46:04 EST 2025
Powered by FUDForum. Page generated in 0.03507 seconds
