Home » Language IDEs » Java Development Tools (JDT) » Unsupported major.minor version 48.0
Unsupported major.minor version 48.0 [message #77983] Fri, 18 July 2003 13:55 Go to next message
Originally posted by: karikday.yahoo.com
While building my project (after successful javac), I get the following
build error: sun/rmi/rmic/Main (Unsupported major.minor version 48.0).
I've read several other threads on several sites regarding this error,
everyone indicating that this problem is caused by 1.3.X to 1.4.X class
file compatibility. All of the source I'm working with is being compiled
and run against 1.4.1. Within eclipse my compiler compatibility is set to
1.3. Can anyone make any suggestions??
Strange piece of information... I was compiling and running this project
yesterday. Today I can't get it to build. The only thing that has
changed is java source.
KD
Re: Unsupported major.minor version 48.0 [message #78125 is a reply to message #77983] Fri, 18 July 2003 16:30 Go to previous message
Are you using the RMI plugin?
This can happen in two cases:
1. you run eclipse using JDK 1.3.1 (use -vm argument to eclipse.exe to
fix it)
2. you have incompatible tools.jar. You should go to the project's RMI
properties and select the "tools.jar" file from jdk 1.4.1 directory.
Genady
> KD
Previous Topic:Unsupported major.minor version 48.0
Next Topic:Using CVS When Source Not In Project Directory?
Current Time: Sun Nov 09 02:12:27 EST 2025
Powered by FUDForum. Page generated in 0.03196 seconds
