Home » Eclipse Projects » Equinox » equinox in a web application in and outside of an rcp application
equinox in a web application in and outside of an rcp application [message #77939] Fri, 24 November 2006 07:28 Go to next message
I would like to know whether is possible to start equinox without the
eclipse executable. I would like to use it within a web application, but
without having to run the web application osgi centric as is described
in the quick starts for serving servlets with equinox (as a matter of
fact I am only using filters).
This webapplication will run within tomcat or jetty (depending on
clustering capabilities).
Also the web application will run partly within an eclipse RCP
application, so then it would probably a good idea to use the standard
eclipse runtime environment for it's osgi capabilities within the same
web application.
Any thoughts on this?
Wouter
Re: equinox in a web application in and outside of an rcp application [message #77955 is a reply to message #77939] Fri, 24 November 2006 09:35 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
See
http://www.eclipse.org/equinox/server/http_quickstart.php
for using Equinox in server configurations
Jeff
Wouter de Vaal wrote:
> web application.
> Wouter
Re: equinox in a web application in and outside of an rcp application [message #77971 is a reply to message #77939] Fri, 24 November 2006 10:04 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
FYI there's a Jetty bundle, which allows you to start up OSGi and then bring up Jetty inside it. OSGi and webapps seem to be all the rage this year; see the http://www.eclipse.org/equinox/server for more information.
Alex.
Re: equinox in a web application in and outside of an rcp application [message #78047 is a reply to message #77955] Mon, 27 November 2006 11:31 Go to previous message
Am I understanding is correctly that all request will be handled by the
bridge servlet? As I am using wicket 2.0, all my requests should be
handled by the wicket filter, which will stand before the servlet
bridge. So my conclusion would be that during wicket requests, no
information about the osgi bundles will be available. Is this correct,
or am I missing something?
Thanx,
Wouter
Jeff McAffer wrote:
> See
> Jeff
>> but without having to run the web application osgi centric as is
>> described in the quick starts for serving servlets with equinox (as a
>> matter of fact I am only using filters).
>> web application.
>> Wouter
Previous Topic:bundle autoloading
Next Topic:Jetty servlet filter bundle?
Current Time: Fri Nov 07 13:47:26 EST 2025
Powered by FUDForum. Page generated in 0.04795 seconds
