Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [teneo]:Newbie tutorial1 question
[teneo]:Newbie tutorial1 question [message #77913] Mon, 02 April 2007 18:30 Go to next message
I'm struggling to get the tutorial1.java program to work for me. The
system does a rollback when it runs JpoxDataStore.createSchema.
2048205 [main] INFO JPOX.RDBMS - Creating index "WRITER_N49" in catalog
"" schema ""
2048205 [main] DEBUG JPOX.RDBMS.DDL - CREATE INDEX WRITER_N49 ON WRITER
(WRITERS_LIBRARY_ID_OID)
2048215 [main] DEBUG JPOX.RDBMS.DDL - Execution Time = 10 ms
2048225 [main] ERROR JPOX.RDBMS - An exception was thrown while
adding/validating class(es) : DB2 SQL error: SQLCODE: -104, SQLSTATE:
42601, SQLERRMC: CASCADE;ON UPDATE;RESTRICT, NO ACTION
com.ibm.db2.jcc.c.SqlException: DB2 SQL error: SQLCODE: -104, SQLSTATE:
at com.ibm.db2.jcc.c.fg.e(fg.java:1596)
at com.ibm.db2.jcc.c.fg.b(fg.java:1160)
I'm using EMF 2.3 teneo 0.8 Eclipse 3.3 and DB2 v9 as my database. I know
that DB2 has not been tested with Teneo but that's the db I plan to use if
Teneo works out. I'm not sure if the problem is the database (I do see
tables are created before the rollback) or soemthing before that. Any
ideas?
btw where are the logs outputing to? I have saw a previous entry in the
newsgroup about it and I have the jars in the java build path and
log4j.properties under /src. I just can't find it.
Julia
Re: [teneo]:Newbie tutorial1 question [message #77929 is a reply to message #77913] Tue, 03 April 2007 04:03 Go to previous message
Hi Julia,
My feel is that it is related to an invalid db constraint creation and not something in your
settings or so.
You can try to do the schema creation separately (outside of teneo):
http://www.jpox.org/docs/1_1/schematool.html#programmatic
It is also possible to dump the schema generation sql in a separate file (see in the top of the
schematool page) so you can try to manually create it in db2 itself.
gr. Martin
> catalog "" schema ""
> know that DB2 has not been tested with Teneo but that's the db I plan to
> use if Teneo works out. I'm not sure if the problem is the database (I
> do see tables are created before the rollback) or soemthing before that.
> Any ideas?
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo]:Newbie tutorial1 question [message #604188 is a reply to message #77913] Tue, 03 April 2007 04:03 Go to previous message
Hi Julia,
settings or so.
gr. Martin
> Any ideas?
> Julia
The Netherlands
Previous Topic:[teneo]:Newbie tutorial1 question
Next Topic:JET2 - multiple input models
Current Time: Sat Nov 08 21:31:12 EST 2025
Powered by FUDForum. Page generated in 0.03771 seconds
