| [ATL] Get model's name [message #77862] |
Fri, 28 March 2008 11:06  |
Originally posted by: bch.bluexml.com
I try to get a weaving model from 2 input models with an ATL
transformation. I need to fill (in the weaving model) the path to access
to models. Is it possible to get it in the ATL transformation ?
| Re: [ATL] Get model's name [message #78022 is a reply to message #77991] |
Mon, 31 March 2008 10:29   |
Originally posted by: mddfabro.ilog.fr
Hi Benjamin,
As Hugo said, ATL does not have a "native" solution to get the path of
models.
However, you can use the AMW Model Handler to obtain such facility.
The model handler has a method called generateModelRef(), which can be
called by any model element. For instance, you can call
MOF!EPackage.generateModelRef('modelname').
'modelname' is the name of the model declared in the ATL header. It
returns a String with the URI of the model.
To be able to use the handler, you must install the model handler
plug-in, and choose 'AMW' in the list of model handlers in the ATL
launch configuration.
The following link has more information about using the handler:
http://wiki.eclipse.org/index.php/AMW_Model_Handler#generate ModelRef
Marcos.
Hugo Bruneliere wrote:
> Hi Benjamin,
> The paths to access to the woven models are not directly stored into the
> weaving model (".amw" file). They are stored into a separated XML
> document (".amw.prop" file) which also contains additional information
> such as the extensions of the core weaving metamodel which are used.
> So basically your ATL transformation will takes as input the 2 woven
> models and will generates as output the weaving model + the XML model
> corresponding to the ".amw.prop" XML file.
> About the problem of directly getting the path of an input model in an
> ATL transformation, it is not realizable with the current version of ATL.
> A solution is to add a parameter model (e.g. an XML model), which will
> contain the missing information (i.e. the paths of the models), as an
> additional input of your transformation.
> I also forward this post to the AMW newsgroup as your problem also is
> indirectly related to AMW.
> Best regards,
> Hugo
> Benjamin CHEVALLEREAU a écrit :
>> access to models. Is it possible to get it in the ATL transformation ?
>> Thanks
| Re: [ATL] Get model's name [message #78343 is a reply to message #78022] |
Fri, 04 April 2008 11:35  |
Thanks for your help, I resolve my problem...
Marcos Didonet Del Fabro a écrit :
> Hi Benjamin,
> models.
> Marcos.
>> Hi Benjamin,
>> the weaving model (".amw" file). They are stored into a separated XML
>> Best regards,
>> Hugo
>>> Hi,
>>> Thanks
FUDForum. Page generated in 0.03869 seconds
