Home » Archived » BIRT » Bar Chart onClick Y Series
Bar Chart onClick Y Series [message #77849] Thu, 29 September 2005 07:40 Go to next message
Originally posted by: romasha.tomar.india.techspan.com
Hi All,
I have created a bar chart in Eclipse 3.1 using the GEF,EMF plugins.
There is an option to redirect to a URL on click of any bar.
When i run the report neither click or hover works for URLRedirect ,
ToolTip,etc.
I tried running the same report on Tomcat as well , but the same warning
gets logged in the server log.
The Warning that gets logged is :
[WARN]: Cannot enable interaction if a component is not associated with
the Swin
gRendererImpl
Am i missing out on any configuration?
Romasha Tomar
Re: Bar Chart onClick Y Series [message #77989 is a reply to message #77849] Thu, 29 September 2005 10:45 Go to previous messageGo to next message
Originally posted by: mpadhye.actuate.com
Hi Romasha,
As of v 1.0.1, chart interactivity is not supported in the report
output (HTML or PDF). If you are however rendering the chart to a SWING
component or generating SVG output, some of the interactivity features
are available.
In the upcoming version (v 2.0) of BIRT, quite a few enhancements to
the interactivity feature are planned. Please see the wiki entry at
http://www.eclipse.org/birt/wiki/index.php?n=BPS.BPS37 for more details.
Milind
romasha wrote:
> Hi All,
> ToolTip,etc.
> the Swin
> gRendererImpl
> Thanks
> Romasha Tomar
Re: Bar Chart onClick Y Series [message #78040 is a reply to message #77989] Fri, 30 September 2005 02:36 Go to previous messageGo to next message
Thanks for the quick response. Wanted to enquire, if i download FireFox
1.0.7 and use IE6+ as mentioned in the link provided by you
http://www.eclipse.org/birt/release20specs/BPS37%20-%20Chart %20Interactivity%20SPEC.pdf.
would chart intercativity work then?
Or is there some other requirement as well.
Have mailed the download to my support group.
Romasha
Re: Bar Chart onClick Y Series [message #78120 is a reply to message #78040] Fri, 30 September 2005 09:48 Go to previous messageGo to next message
This is a multipart message in MIME format.
--=_alternative 004BE4478525708C_=
Content-Type: text/plain; charset="US-ASCII"
If you render the charts in SVG you can use either IE or Firefox. For IE
you will need a SVG viewer plugin. So far the SVG charts have been tested
with Adobe SVG viewer 3.x (you can download this viewer at
http://www.adobe.com/svg). For Firefox the plan is to support the
upcoming 1.5 version that has native SVG support. The beta version of
Firefox 1.5 can be downloaded at http://www.mozilla.org/projects/firefox/.
- Sheldon
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">If you render the charts in SVG you
can use either IE or Firefox. &nbsp;For IE you will need a SVG viewer plugin.
&nbsp;So far the SVG charts have been tested with Adobe SVG viewer 3.x
(you can download this viewer at http://www.adobe.com/svg). &nbsp; For
Firefox the plan is to support the upcoming 1.5 version that has native
SVG support. &nbsp; The beta version of Firefox 1.5 can be downloaded at
http://www.mozilla.org/projects/firefox/.</font>
<br><font size=2 face="sans-serif">- Sheldon </font>
--=_alternative 004BE4478525708C_=--
Re: Bar Chart onClick Y Series [message #78316 is a reply to message #78120] Mon, 03 October 2005 03:01 Go to previous messageGo to next message
Thanks for the detailed description.
I downloaded FireFox 1.0.7 as well as FireFox 1.5 .But there was no report
interactivity available.
Installed the adobe svg viewer. it gets installed automatically after
running setup.Isnt there any location where it gets installed? Do i need
to do anything special to use it.I am currently using IE6.0. and the same
issues of no interactivity available.
I am pasting the report i am trying to run.
on load of the report i still get the same warning
the SwingRendererImpl
Is it expecting only swing rendering?
<?xml version="1.0" encoding="UTF-8" ?>
- <!-- Written by Eclipse BIRT 1.0
- <report xmlns="http://www.eclipse.org/birt/2005/design" version="2">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1 Build
<20050729-0746></property>
<property name="units">in</property>
- <data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.sampledb"
name="Sample" />
</data-sources>
- <data-sets>
- <oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Customers">
<property name="dataSource">Sample</property>
<property name="queryText">select * from customers where
country='USA'</property>
</oda-data-set>
- <oda-data-set
name="Test">
<property name="queryText">select count(productcode)as
countofproductcode, productline as productline from products group by
productline</property>
</oda-data-set>
</data-sets>
- <page-setup>
- <simple-master-page name="Simple MasterPage">
- <page-footer>
- <grid>
<property name="width">100%</property>
<column />
- <row>
- <cell>
- <text>
<property name="contentType">html</property>
- <text-property name="content">
- <![CDATA[ <value-of>new Date()</value-of>
</text-property>
</text>
</cell>
</row>
</grid>
</page-footer>
</simple-master-page>
</page-setup>
- <body>
- <text>
<property name="contentType">plain</property>
- <![CDATA[ First report
</text-property>
</text>
- <grid>
<property name="height">0.739in</property>
<property name="width">5.979in</property>
<column />
- <row>
<property name="verticalAlign">text-bottom</property>
- <cell>
<property name="verticalAlign">top</property>
- <label>
<property name="fontWeight">bold</property>
<property name="textUnderline">underline</property>
<property name="textAlign">center</property>
<text-property name="text">Report Header</text-property>
</label>
</cell>
</row>
</grid>
- <extended-item extensionName="Chart">
<property name="height">250pt</property>
<property name="width">700pt</property>
<property name="dataSet">Test</property>
- <xml-property name="xmlRepresentation">
- <![CDATA[
<model:ChartWithAxes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Stacked</SubType>
<Description>
<Value>=Cars</Value>
<Font>
<Name>SansSerif</Name>
<Size>12.0</Size>
<Bold>false</Bold>
<Italic>false</Italic>
<Strikethrough>false</Strikethrough>
<Underline>false</Underline>
<Alignment>
<horizontalAlignment>Left</horizontalAlignment>
<verticalAlignment>Top</verticalAlignment>
</Alignment>
<Rotation>0.0</Rotation>
</Font>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>=Bar Chart Title</Value>
<Font>
<Size>24.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value>&lt;undefined></Value>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Position>Right</Position>
<ItemType>Categories</ItemType>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>699.75</Width>
<Height>249.75</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5.0,4.0,12.0</DataSetRepresentation >
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>=Product line</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>=Y Axis</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>0</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row[&quot;COUNTOFPRODUCTCODE&quot;]</Definition >
</DataDefinition>
<SeriesIdentifier>&lt;undefined></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Prefix></Prefix>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>true</Stacked>
<Triggers>
<Condition>Mouse_Hover</Condition>
<Action>
<Type>Show_Tooltip</Type>
<Value xsi:type="attribute:TooltipValue">
<Text>asdsadsad</Text>
<Delay>200</Delay>
</Value>
</Action>
</Triggers>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
</SeriesDefinitions>
<GapWidth>0.0</GapWidth>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>204</Red>
<Green>153</Green>
<Blue>254</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row[&quot;PRODUCTLINE&quot;]</Definition >
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
<Stacked>false</Stacked>
</Series>
<Grouping>
</Grouping>
<Sorting>Ascending</Sorting>
<Orientation>Horizontal</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Below</LabelPosition>
<Staggered>false</Staggered>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
<CategoryAxis>true</CategoryAxis>
</Axes>
</model:ChartWithAxes>
</xml-property>
</extended-item>
</body>
</report>
Thanks for being patient
Re: Bar Chart onClick Y Series [message #78412 is a reply to message #78316] Mon, 03 October 2005 09:37 Go to previous messageGo to next message
--=_alternative 004AE3548525708F_=
I believe the charts are generated as static images by default. You may
have to set an option in the report design template to generate the charts
as SVG. What type of interactive capabilities are you looking for?
Currently the report designer does not allow the user to change the output
type of the charts to SVG. In 2.0 the option to specifiy whether to
generate the charts as SVG will be there.
<br><font size=2 face="sans-serif">I believe the charts are generated as
static images by default. &nbsp;You may have to set an option in the report
design template to generate the charts as SVG. &nbsp;What type of interactive
capabilities are you looking for? &nbsp;Currently the report designer does
not allow the user to change the output type of the charts to SVG. &nbsp;In
2.0 the option to specifiy whether to generate the charts as SVG will be
there.</font>
--=_alternative 004AE3548525708F_=--
Re: Bar Chart onClick Y Series [message #78845 is a reply to message #78412] Tue, 04 October 2005 06:41 Go to previous message
Thanks for consistently replying.
When is BIRt 2.0 being planned for release?
I cannot understand , if the feature is not supported then why does it
display the options?
Previous Topic:How to add a page number.
Next Topic:Listing in one line
Current Time: Sun Jul 27 12:41:38 EDT 2025
Powered by FUDForum. Page generated in 0.06436 seconds
