Setting up debug with WL localhost [message #77820] |
Tue, 14 June 2005 14:34  |
Originally posted by: Chris.Loschen.Siebel.com
Hi all,
I have a project set up in Eclipse which I'm developing with. The same
project is then built into ear files via ant and that is deployed to a
WebLogic 8.1 SP4 instance on localhost (and which in turn interacts with an
Oracle 9.2 DB also on localhost). All of that is working ok.
However, I'm now trying to set up debugging for the project, and running
into trouble. I was told to include this line in my WL startup script:
@set
JAVA_OPTIONS=%JAVA_OPTIONS% -Xdebug -Xrunjdwp:transport=dt_socket,suspend=n,server=y,address=250 00
which I did. I set up Eclipse to listen on port 25000, and I do see the
threads listed as they are running. However, the system is now quite
unstable: I get VM HotSpot crashes saying "parallel GC allocation failed"
and other crashes without any error message at all, but which close down
java entirely. I remove the debug line and the problems go away.
I'm sure I've set up something incorrectly: any suggestions? Thanks!
Chris Loschen
Siebel Systems
Re: Setting up debug with WL localhost [message #78768 is a reply to message #77820] |
Fri, 17 June 2005 14:47  |
I made a little progress here, but it still isn't working. I found a plug-in
that is supposed to help work with Weblogic in Eclipse (from BEA at
http://dev.bea.com/codelibrary/code/wlplugin.jsp). I installed it, and set
up my project so that it has the same java options, memory requirements,
etc. But now I'm getting this error. Any ideas? The plug-in says that it's
compatible with WL 8.1, which is what I'm running. Thanks!
The WebLogic Server did not start up properly.
weblogic.common.internal.VersioningError: Incompatible packages in
CLASSPATH: (BEA Systems, WebLogic Server 8.1 SP4 Mon Nov 29 16:21:29 PST
2004 471647 , 8.1.4.0) not compatible with (BEA Systems, WebLogic Server 7.0
SP4 Tue Aug 12 11:22:26 PDT 2003 284033 , 7.0.4.0)
at weblogic.common.internal.VersionInfo.verifyPackages(VersionI nfo.java:173)
at weblogic.common.internal.VersionInfo.<init>(VersionInfo.java:65)
at weblogic.common.internal.VersionInfo.initialize(VersionInfo. java:127)
at weblogic.common.internal.VersionInfo.theOne(VersionInfo.java :98)
at weblogic.version.getPLInfo(version.java:57)
at weblogic.t3.srvr.T3Srvr.checkAccess(T3Srvr.java:523)
at weblogic.t3.srvr.T3Srvr.initializeHere(T3Srvr.java:716)
at weblogic.t3.srvr.T3Srvr.initialize(T3Srvr.java:670)
at weblogic.t3.srvr.T3Srvr.run(T3Srvr.java:344)
at weblogic.Server.main(Server.java:32)
Reason: Incompatible packages in CLASSPATH: (BEA Systems, WebLogic Server
8.1 SP4 Mon Nov 29 16:21:29 PST 2004 471647 , 8.1.4.0) not compatible with
(BEA Systems, WebLogic Server 7.0 SP4 Tue Aug 12 11:22:26 PDT 2003 284033 ,
7.0.4.0)
I am adding quite a few jar files to the CLASSPATH, but none of them are
BEA-related. Perhaps I need to add the 8.1 WL jars to the classpath before
the ones that the plug-in uses?
Chris
"Chris Loschen" <Chris.Loschen@Siebel.com> wrote in message
news:d8n804$evs$1@news.eclipse.org...
> Hi all,
> an Oracle 9.2 DB also on localhost). All of that is working ok.
> @set
> Chris Loschen
> Siebel Systems
FUDForum. Page generated in 0.09937 seconds
