PHP items on "Run as..." menu still visible in Java and other perspectives [message #77745] |
Mon, 04 August 2008 11:08  |
Originally posted by: secretcode343.gmail.com
I've installed PDT but I also code in Java, Perl and C++. The PHP-related
items on the "Run as..." menu appear whatever the source code file I'm
editing is, and whatever perspective I'm in.
I think this is the wrong behaviour, but even if it's by design, can I
prevent it?
I haven't seen this problem mentioned in my searches here or across the
web, but I can't use very specific search terms.
By comparison, 'Java application' doesn't appear when in the C++
perspective, 'Local C/C++ application' doesn't appear when in the Java
perspective, etc.
I am not a plugin developer and won't be able to understand the full ins
and outs of building an IDE plugin but I don't mind getting into the
detail of how Eclipse builds the "Run as" menu.
I have Eclipse 3.3 and PDT 1.0.3. I also have CDT 4.0.3, and EPIC (Perl)
0.6.24 (installed before PDT).
Again, how can I prevent PHP items appearing on the Run as menu in other
perspectives?
thanks!
Re: PHP items on "Run as..." menu still visible in Java and other perspectives [message #77761 is a reply to message #77745] |
Mon, 04 August 2008 11:53   |
Originally posted by: codeslave.ca.ibm.com
Window > Customize Perspective... ?
> PHP-related items on the "Run as..." menu appear whatever the source
> code file I'm editing is, and whatever perspective I'm in.
> prevent it?
> perspective, etc.
> perspectives?
> thanks!
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
FUDForum. Page generated in 0.04122 seconds
